Fairly critical take on how Toyota has repositioned the Tundra
Discussion in '3rd Gen Tundras (2022+)' started by OnThaLake, May 25, 2022.
  1. Jun 3, 2022 at 7:49 PM
    #211
    Breathing Borla
    AZ
    As far as gen 2 or 2.5, vs gen3 pulling , my guess is gen 3 hands down, more torque at a much lower rpm with a 10-speed behind it, kinda a no brainer which is why Toyota did it
    FLTon, TMack77 and Melikeymy beer like this.
  2. Jun 4, 2022 at 6:49 AM
    #212
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    What I'm getting at is it could be even better - an HD version would obviously be setup better the deal with the heavy loads, and the the 1/2 ton could be even nicer just driving around. Toyota has to make compromises where the big 3 don't.
    And bigger payload/towing numbers don't necessarily mean it does those things more comfortably. That was the big advantage the 2nd gen had over the big 3 - you could tow/haul at it's limits and it was extremely comfortable, almost more so than empty. I'm really curious how the frame/chassis/suspension does when loaded up - is it still very confident feeling like the 2nd gen was or have they compromised a bit
    Cpl_Punishment likes this.
  3. Jun 4, 2022 at 7:16 AM
    #213
    Outbound
    Aaron
    Northern Alberta
    Fair concerns. Everything I've read so far though is that the 3rd Gen tows much better than the 2nd Gen. There's a thread on here about towing with it and of the posters are people who came from 2.5 gen. TFL (even though I think they're clowns), actually did a good run up Pike's Peak with hauling an 8000lb trailer and the feedback they gave was all positive, especially coming from the Ford fangirls they are.
    RookieEP likes this.
  4. Jun 4, 2022 at 1:26 PM
    #214
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    I am just getting back from a trip. thanks for these opinions (below) on why you would keep the 2.5 instead of going to the 3.0.
    Always interested in more opinions whenever a matter is open. In this case as long as I am able to get a crazy amount for trade in value, the matter is open, but on the other side buying at MSRP offsets it. And there are no trucks available to buy anyway. When I was coming back gas was $2.10 Liter. My truck has a 38 gallon tank so 143 liters. I filled from half. It cost me as much as that new boat starting battery I bought, and the battery will last me 5 years. Just saying. rant.
    Wanted to mention something that happened a couple of days ago that has me more concerned about the......front tow hooks (lack of on the 3rd gen). The boats we usually launch fishing/bowriders/runabouts go into natural lakes with sand/mud bottoms, many with shallow level entries so sometimes..... you are into the lake (all 4 wheels) to get deep enough to float the boat off. Someone launched a boat with a pickup. The brand doesn't matter. What matters is when he went to pull the boat out, his wheels were spinning and he started sinking down into the mud. Another truck helped him out and hooked up to his front tow hooks.
    So this forum and all the discussion about the lack of tow hooks got me thinking about this. What if it was a 3.0 Gen Tundra that happened to? Has someone found a place to hook onto without doing a lot of damage to the front body ?
    in_the_mud likes this.
  5. Jun 4, 2022 at 5:18 PM
    #215
    TMack77
    TMack77 New Member
    Windsor, Ontario
    2022 Tundra Capstone Blueprint
  6. Jun 4, 2022 at 5:42 PM
    #216
    Breathing Borla
    AZ
    How do you even pull from those without ripping the entire front of the truck off? If your nose down at all that’s a lot of digging
    better than nothing I guess
    they just didn’t design this new truck for that stuff is my thought , too much nose overhang
    if your into that bumber replacement is the way to go
  7. Jun 5, 2022 at 6:24 AM
    #217
    borla123
    borla123 The Pits
    Ontario
    So in looking at the picture in the link, that places the recovery hooks in line with the front wheels.
    Yeah, that's a lot of real estate in front compared to the previous version.
    Any pull will also bring an upward motion, so they are not there to not damage anything but to hopefully get you out.
    Assuming everything in front of the hooks on the 2022 is designed as a crumple zone and the reason they are so far back. It does make me wonder how Ford and the others can have the hooks in front and still maintain the safety ratings. Why not Toyota ?
  8. Jun 5, 2022 at 6:52 AM
    #218
    belanger9
    Edmonton, AB
    A bunch
    Toyota looks like they've gone a different direction than Ram especially - the Ram engine is that far back from the bumper as well but this cause a hump in the footwell that's extremely noticeable in the passenger seat. Toyota looks like they've kept the engine, hybrid unit, and transmission out of the footwells but this causes the extra foot of space in front of the wheels for coolers and crash structure.
    I bet Toyota could easily come up with a tow hook 'option' that would require either a new front bumper or some cut outs for semi style tow pins, and neither would be overly costly with the TRD off road packages being quite high sellers and would expect that to be the standard to come with that option.
    It will be interesting to see how they put tow hooks on the new Tacoma - just cannot see them not putting tow hooks on the Tacoma which has had the better off road gear over the Tundra. And I don't see a reason why the concept couldn't be transferred over to the Tundra, would only need a different bumper.
  9. Jun 5, 2022 at 8:51 AM
    #219
    Jaxyaks
    Jaxyaks New Member
    They are just better than others at getting them build probably, the have sold 127,116 Rams thru March of 2022. Toyota has done 37,218 thru May of 2022.
  10. Jun 5, 2022 at 12:17 PM
    #220
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
  11. Jun 6, 2022 at 5:28 PM
    #221
    pursuit2550
    pursuit2550 New Member
    Now is that figure 1/2 ton only. The big 3 group their entire line up together when it comes to sales figures. If I recall Ford even counts up to the F550 class. Not that Toyota will ever out sell the big 3 but I have yet to see numbers for just 1/2 tons
    TMack77 likes this.
  12. Jun 8, 2022 at 9:57 AM
    #222
    cemarshall
    cemarshall New Member
    2022 SW Tundra TRD Pro
    Roll-n-Lock A Series Bed Cover, Rough Country AL2 Drop Steps, JDM stage 3 OBD2 plug n play
    My estimation would be about 7-8,000 lbs with the trailer and 2 horses plus give or take 800 lbs of payload
    OnThaLake[QUOTED][OP] likes this.
  13. Jun 8, 2022 at 10:04 AM
    #223
    cemarshall
    Yeah, after driving both gens, I can confidently tell you that the 3rd hauls just as comfortably if not better because of the significant increase in power and top of the line suspension I've got in my pro. That truck is the best driving truck I've owned to this point. I am a bit biased, as we all are in some ways. But the numbers speak for themselves there. That's the difference in engineering between Toyota and the big 3. They play the higher number war on paper. Where Toyota sets their numbers based on what they know will tow/haul comfortably at the limits they put on paper.
    belanger9[QUOTED] and FLTon like this.
  14. Jun 9, 2022 at 4:13 PM
    #224
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    I came from a 1st gen Ridgeline, & yes the first thing I knew I was loosing was a ton of functional storage space, with the trunk, & cab storage cubbies etc. I had a lot of organized space to store stuff, stock from the factory, now I have less. Everything that came out of my Ridgeline still hasn’t found a proper storage spot in the tundra yet. Still being creative with some things. It would be even worse with a hybrid.
    i have the truck I wanted, not complaining, but confirming above comment about cubic storage space.
