F11 any good?
Discussion in 'Detailing' started by AK 6.7PSD Replacement, Jul 27, 2019.
  1. Jul 27, 2019 at 1:26 PM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    is F-11 any good? Should I just clay/wash/wax or use this stuff?
    driverdog likes this.
  2. Jul 27, 2019 at 1:51 PM
    War Machine
    War Machine SSEM # 5 3MW
  3. Jul 27, 2019 at 8:21 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What brand clay mitt are you using Jim?
    I have a blackfire mit that I like and recently got a nanoskin 6" disc that can go on a DA if you wanted to do that, I just use it by hand. The nanoskin is MUCH better than the blackfire. I did try it on the DA and wow was it fast but I didnt like the lack of "feel". Anyway I'm looking for a new mitt or towel and will take your recommendation if you'd give it up.
    A tip, I picked up by accident when using a clay mit. I dunk it in my bucket of wash soap (reset) and fill the inside of the mitt with wash solution, I don't stick my hand it in. So basically use the mitt as a bucket to hold some reset and water. I just hold it upright by the other side of the mitt, as I go along the side of the car, the wash solution gets pushed up and out, adding some lubrication. Works well to keep the surface lubricated.
    I also spray a mix of ech20, immolube,and water. Idk if you've tried the immolube yet but it's cool stuff. Can be diluted down and added to various mixtures. Adds a lot of slickness but also some tack if that makes sense. I have a bottle 3:1 that i mist on my DA pads to keep them cool and prolong the working time of the product, works well.
  4. Jul 28, 2019 at 2:59 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    It’s good for a month or two. Only I used it once. Idk if I’d spend good money on it tho. My detailer did it for free. Looked great and beaded water fine. This is right after I picked it up
    War Machine likes this.
