Extremeaire Compressor system
Discussion in 'General Tundra Discussion' started by Wikid, Jul 10, 2015.
  1. Jul 10, 2015 at 6:43 PM
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    This is the compressor install I did on my FJ, a few years ago
    I did a similar install in a fellow FJ Cruisers truck yesterday. I do plan on making the same type of mount for the Tundra
    I wasn't sure where to post this, but I wanted to give you guys an idea of how this will turn out. I may increase the air tank size from 2 gallon to 4 gallon, depending on available space . I know there was a thread here where someone was complaining about this compressor not being that good, but that is for sure not the case.
    (4) 35X17 tires filled from 14 psi to 40 in just about 6 minutes. It's not as fast as a Powertank, but It's fast and you can run air tools . 100% Duty cycle
    2 air chucks on opposite corners
    Main wires are 4 gauge
    100 amp circuit breaker
    I should have something mocked up right after I get back from my Colorado trip
    T-Rex266 and dandailey like this.
  2. Jul 10, 2015 at 8:19 PM
    Nice. We will have to add that to DIY list if you can write up the details on install.
    Wikid[OP] likes this.
  3. Jul 10, 2015 at 8:38 PM
    Lancelotlink
    Lancelotlink New Member
    Lance
    Interested in this mod for sure. Not for filling tires but for filling kites for kiteboarding. (Unfortunately not me in the pic).
  4. Jul 11, 2015 at 10:15 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Nice, I'd like to have compressed air on my truck, but the concern I have is having it all under the truck where it could be damaged. Wonder if there is some armor you could put below it.
  5. Jul 11, 2015 at 10:57 AM
    Mike Tread lightly.
    south carolina
    I went c02 and be done. Plus cheap to recharge.
  6. Jul 11, 2015 at 11:46 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    ive been wanting to do that with airbags
  7. Jul 11, 2015 at 12:36 PM
    Wikid
    Don
    On order
    Thanks, I will be writing it all up
    I suppose it can be used any way you wish . Bouncy house may be a little much but the Kiteboard would work
    Under my FJ for 2 years without any problems. If you get hung up that high into the rear section, you may have other problems than the tank. Everything is above the frame rails . I was planning on building a skid for it though
    I went down that road. I was looking for a solution that didn't involve a tank, you have to find a place to store and being married to going to fill up the co2 . Different strokes for different folks
    It would work well for air bags. Especially if you could control them from the drivers seat. It would just take a few control valves
