Extra 4" cable with Maestro RR - what is it? [SOLVED]
Discussion in 'Audio & Video' started by BrakeDust, Apr 12, 2021.
  1. Apr 12, 2021 at 4:52 PM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Anyone know what this is? It's not in the Maestro diagram, nor is it in their "do not use" list. One side fits into the Maestro, the other side doesn't seem to have a counterpart in the Toyota OEM cables. 2021 SR5, non-JBL.
    Thanks
  2. Apr 12, 2021 at 5:12 PM
    It had something to do with the front speakers I believe. You don't need it. I just threw it in a bag with the other cables that weren't needed. Everything pretty much goes through that data cable.
    Another thing that I noticed as well is no matter which selection you make to flash the module (amp, without amp, etc), the wiring diagrams all seem to be the same. You do not need to run the cable to the OBD port either.
  3. Apr 12, 2021 at 5:29 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Do you still get TPMS and factory option controls then?
  4. Apr 12, 2021 at 5:33 PM
    Yes, it is all through the data cable. All of the wiring in the box is like an "all in one" kit. Some vehicles will use them, some will not.
  5. Apr 12, 2021 at 5:49 PM
    BrakeDust
    Hill Country, TX
    Thanks!!
    There's also a couple plugs on the maestro harness that look identical to each other, possibly one for each side of the unit. Per the diagram it appears only one needs to be connected. One is brown, other is black. I'm thinking I should just plug in everything that fits. Is that safe?
  6. Apr 12, 2021 at 5:57 PM
    Usb retention adapter is available now....just ordered one.
    https://www.crutchfield.com/p_794USBTO3/iDatalink-UTO3-Adapter.html
  7. Apr 12, 2021 at 5:58 PM
    Let me grab my bag so that you can see what is not used.
  8. Apr 12, 2021 at 6:07 PM
    Here is everything that was not used when I installed mine.
  9. Apr 12, 2021 at 6:34 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Interesting, looks like you 2020+ guys have a slight change to the wiring diagram vs 2014-2019:
  10. Apr 12, 2021 at 6:38 PM
    Yep. The 2020 doesn't even use the OBD cable.
