Explain it to me like I'm 5. Mid Travel Suspension
Discussion in 'Suspension' started by Lars, Jun 27, 2018.
  1. Jul 15, 2018 at 8:57 AM
    #61
    n2deep
    n2deep Pavement Princess
    Proof that it can happen to any if the brands. Top cap pulled out either from rotating and catching sonething on droop or poor build QC. Have seen the top cap come out on every brand but King but they have a different top design on the OEM replacements than the others. But easily fixed with replacement parts and don't have to replace the whole shock.
    dcsleeper408 likes this.
  2. Jul 15, 2018 at 9:19 AM
    #62
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    To answer the question about Kings, my shocks are delayed further because of the fitment issues. My assumption is due to the possibility of rotation or bypass tube placement, but delayed nonetheless.
  3. Jul 26, 2018 at 7:16 PM
    #63
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Any interested out there in some new rear hydros? Its a bolt on kit. Shoot me a PM if you may be interested. Cheers
  4. Apr 24, 2019 at 9:23 AM
    #64
    zackbremer
    zackbremer New Member
    Da Z
    check my build thread for taking MT as far as you can go..im at 12.5in up front and 14in in the rear
    osidepunker and dcsleeper408 like this.
  5. Apr 30, 2019 at 12:58 PM
    #65
    Justin@bajakits
    Justin@bajakits Suspension dude
    Justin
    California
    07-17 Tundra: Bajakits chase kit demo vehicle
    Bajakits Chase kit: UCAs with king 2.5 coilovers Bajakits Rear Chase kit: Deaver F85 pack with King 2.5 Remote Resi.
    One thing I have heard from other guys buying shocks second hand. Or ordering from a company that did not know, possibly inexperienced, is the fact that some guys will get OEM Replacements and not get an EXT made shock (extended due to internal shock spacer removal). This is done when there is an aftermarket leaf pack added which in turn gets a bit more travel than stock leafs. Or we order a longer shock depending on the planned kit/use for the truck. But guys will think they have that option but do not.
    Thus running into big issues maxing the shock out internally causing damage over time. The top threads could be the weak point in the equation and let go due to downward force in a "whoop" style section or articulation. Lots of us push our trucks harder than we are suppose to with the current setup which is why we upgrade over time. Just some insight, hope that helps a little as well as makes a bit of sense!:burnrubber:
    GiantsFanDan likes this.
  6. May 3, 2019 at 8:50 PM
    #66
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    This is an articulate response.
    You must not be from around here.
    We deal mostly in vagaries and balderdash. If you can throw in a ‘my friend said...’ here and there, that will lend you some credibility. My friend said so. :anonymous:
  7. May 3, 2019 at 9:04 PM
    #67
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Better suspension than stock, not quite LT.
