Exhaust "Tick"
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, May 14, 2015.
  1. May 14, 2015 at 12:48 PM
    Rkcruza
    Rkcruza [OP] New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Anyone had issues with the stock 1st gen exhaust manifolds? Mine developed a "tick" when cold which is most likely a small crack or slightly warped flange. From what I understand, swapping out the manifolds is a real PITA on 1st gens so I have simply ignored it for about 2 years (goes away when she warms up).
  2. May 14, 2015 at 1:06 PM
    Mike Tread lightly.
    south carolina
    You sure its not the gasket gone bad?
  3. May 14, 2015 at 8:55 PM
    T-Rex266 Moderator Staff Member
    This
    Or can it be an exhaust leak?
  4. May 14, 2015 at 9:57 PM
    Rkcruza
    Bob
    Not sure what it is....it started a couple years back...local mechanic said Tundras had issues with the exhaust manifold cracking. Hasn't gotten any worse and still passes smog so I've sort of ignored it as it goes away when warmed up. Can't really get to a spot to look at it as the 4.7 is crammed in pretty tight in the 1st gen and there is tin shrouding around it all. Just thought I'd see if anyone has had a sim issue...
  5. May 15, 2015 at 6:08 AM
    Mike Tread lightly.
    south carolina
    I have the 4.7 with 144 on the clock no leaks at all yet. Toyota is not the best at manifolds.
  6. May 18, 2015 at 9:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Go for the headers and gain performance while fixing the tick
    Bear, 15whtrd and LOTSOFTOYS like this.
  7. Oct 15, 2015 at 4:02 PM
    rdp5008
    rdp5008 New Member
    Russell
    2001 Tundra SR5 2wd
    ARE Camper Shell
    I have the cold tick at 135k. Something to do with exhaust manifold (crack or bad gasket?). Heard it was a common thing. Doesn't seem to impact performance or mpg though.
  8. Oct 15, 2015 at 6:53 PM
    Rkcruza
    Bob
    I have heard that the tube type manifolds get cracks. Mine has the tick on the drivers side...been there for a few years and still passes smog etc. Haven't changed it as they are a PITA to change out on the early Tundras.
  9. Oct 16, 2015 at 11:54 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Common on early 4.7s... Cracked manifolds
  10. Aug 6, 2017 at 10:35 AM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    When you get ready to do your next 90k service replace the manifolds at the same time. My manifolds came out in 2 pieces when they went to change the gaskets. 102k at the time.
  11. Aug 26, 2017 at 7:17 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    My 2000 ticks for a little while until the headers get hot, then sounds normal. I figure I'll just run them until it gets worse then throw a new performance set on.
  12. Oct 18, 2017 at 6:19 AM
    Black Rollover
    Black Rollover New Member
    David
    2004 Tundra Double Cab Ltd
    I have heard good things about these replacement manifolds. Way cheaper than OEM, like Amazon for 165.00
    Dorman 674-683 Exhaust Manifold Kit
  13. Dec 21, 2018 at 5:27 AM
    FirstGenVol
    FirstGenVol No ABS club-founding member
    East TN
    2002 AC TRD 4x4 V8
    Reading through this thread I'm glad I'm not the only one that has the tick until the engine warms up. It's annoying.
    Has anyone gone put headers on their 4.7L?
  14. Dec 21, 2018 at 6:13 AM
    Casper421
    Casper421 Internet asshole
    CA
    06 DC
    A few have but I’ve read that they are a bitch to install. LT headers and exhaust from @dirtydeeds is on my list.
  15. Dec 21, 2018 at 6:16 AM
    Somemedic
    Mark
    Whatever the lifetime warranty stuff advance auto sells.
    New exhaust and gaskets cleared that tick right up
  16. Dec 21, 2018 at 6:21 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My '02 had a tick, I replaced the stock manifolds with JBA short tubes.
    I haven't heard a tick since then... that was 130k+ miles ago.
    I used OEM gaskets.
    Casper421 likes this.
  17. Dec 21, 2018 at 6:23 AM
    Casper421
    CA
    06 DC
    Did you install them yourself? If so, how difficult was it?
    Rex Kramer[QUOTED] likes this.
  18. Dec 21, 2018 at 6:29 AM
    mgxsequioa
    mgxsequioa New Member
    I had an 01 Sequioa with ~250k miles and had the tick that started at ~120k miles and went away when it warmed up. FWIW - multiple local mechanics indicated that if it were their truck, they wouldn't do anything about it.
  19. Dec 21, 2018 at 6:34 AM
    Rex Kramer
    Georgia
    Dealer installed.
    Casper421[QUOTED] likes this.
  20. Dec 21, 2018 at 11:54 AM
    Rkcruza
    Bob
    Manifolds are relatively inexpensive, installation is a PITA due to limited access. Mine has had the tic for about 10 years. Was told way back when to let it go until it got bad. Hasn't seemed to change much over the years so I simply ignore it.
    Filthyphil likes this.
  21. Dec 21, 2018 at 1:31 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you remember what they charged? I saw you going back and forth with someone in another thread about those short tubes. Did you lose torque like suggested?
  22. Dec 21, 2018 at 5:28 PM
    Filthyphil
    Phil
    Does it just tick until warm or constantly?
  23. Dec 21, 2018 at 6:45 PM
    Rex Kramer
    Georgia
    I don't recall the labor charge.
    The headers did boost HP & Torque noticeably, the fact that I added an LSD and a
    rear sway bar at the same time made these gains even more noticeable to me.
