Exhaust dump before or after rear axle?
Discussion in 'Performance and Tuning' started by Txhouse, Mar 21, 2018.
  1. Mar 21, 2018 at 5:43 AM
    Txhouse
    Txhouse [OP] New Member
    Aaron
    2018 Tundra SR5 Crewmax 4x4
    Stock for now.
    All,
    I've seen many people speak of dumping the exhaust pipe to help reduce drone. I see of lot of the dumped exhaust from the manufacturers have a turn down straight off the muffler but every post I've seen on this forum says to dump after the rear axle. Is there a specific benefit to this or is it just easier?
  2. Mar 21, 2018 at 5:53 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    I would think it helps cut down on in cab noise being further away. :notsure:
    TRD-tv and Mountun Goat like this.
  3. Mar 21, 2018 at 7:13 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I dumped mine after the axle recently. I'd say the drone is slightly more noticeable after dumping. I have a resonator installed in the bend of the pipe, just behind the axle.
    Mountun Goat likes this.
  4. Mar 21, 2018 at 7:35 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    mine is before.
  5. Mar 21, 2018 at 7:47 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Rule of thumb:
    Exit as far back as possible and exit the vehicle completely.
    Dumping after axle at least follows part of the rule.
    When a customer asks for a dump I normally try to figure out if drone is a concern for them. If it is then I try to talk them out if a dump. But if it absolutely has to be dumped then after the axle is the next choice.
  6. Mar 21, 2018 at 7:55 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Before axle( under cab) will be loud in the cab. The further back you dump it the less cab noise
  7. Mar 21, 2018 at 1:13 PM
    Txhouse
    Aaron
    Stock for now.
    Thanks all, makes perfect sense. I was just curious after reading all the other posts.
  8. Mar 21, 2018 at 1:17 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Not only will it be louder but you’ll be huffing exhaust all day long while idling and outside your truck. Such as putting groceries in it. Or your kids. Which isn’t cool imo.
    831Tun likes this.
  9. Mar 21, 2018 at 1:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've got the TRD dual and it's dumped in front of the axle. My ride height required that I remove the tail pipes 'cause they were hitting the leafs.
  10. Mar 21, 2018 at 1:47 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ll be doing this after lift as well. I’ll be chopping all the fender add behind my rear wheels so most likely dump infront of rear wheels. I don’t like exhaust fumes. But I’ll take em for cool truck factor haha
    831Tun[QUOTED] likes this.
  11. Mar 21, 2018 at 2:01 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I had the same situation as @831Tun
    But I marked and cut the pipes right where they would be hitting the springs. This got the “dump” farther to the rear and aimed outward.
    4E3D23D7-FEB3-4F32-938C-379EA4CFAA25.jpg 3A34E6C2-88F2-4560-B79C-852185B46598.jpg
    Keep in mind, these pictures are taken with the wheel off the ground and in full droop. Normally the exhaust is exiting below the springs not into them.
  12. Mar 21, 2018 at 2:32 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I like it. Good idea
    gosolo[QUOTED] likes this.
  13. Mar 21, 2018 at 2:40 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Actually a much better solution. My dumped pipes tend to "leaf blow" any dust that's under the truck.
  14. Mar 21, 2018 at 2:55 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    very nice!
    need to get your rear diff breather mod on.
    GodlessPro and gosolo[QUOTED] like this.
  15. Mar 21, 2018 at 3:02 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah you are right, I’m just a slacker
  16. Mar 21, 2018 at 4:01 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    FOUND!
    @dcsleeper408
    Where’s that mod thread for the rear diff breather? I looked but could not find it
  17. Nov 1, 2021 at 11:10 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    What size turnout can we bolt to the factory pipe?
    dirtydeeds and gosolo like this.
  18. Nov 1, 2021 at 11:20 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This thread is over 3 years dead. (intentional rhyming)
    you might be better off starting a new thread, lol
  19. Nov 1, 2021 at 1:05 PM
    dirtydeeds
    Keith
    USA
    Anybody reading this that has cut the stock tailpipe and is tired of the drone caused by that. We have a solution now. It’s a direct bolt on. The install starts at about 10 minutes in this video:
    https://youtu.be/i79q3q3kaHs
    it’s the same Helmholtz resonator but we make it longer and it works really well at getting rid of the drone from cutting the stock tailpipe.
    gosolo likes this.
  20. Nov 1, 2021 at 1:49 PM
    dirtydeeds
    Keith
    USA
    The factory connection is a weird flange.you’d be best to cut the stick tailpipe after the axle. This would accomplish your goal of dumping under the truck. And it would maintain your low end torque.
  21. Nov 1, 2021 at 5:33 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Thank you
