Exhaust Clamp Issue
Discussion in 'General Tundra Discussion' started by back_cast, Aug 17, 2021.
  1. Aug 17, 2021 at 12:29 PM
    back_cast
    back_cast [OP] New Member
    Denver, CO
    I noticed my tail pipe was drooping some behind the passenger rear tire a couple of years after installing dirty deeds mufflers while utilizing the stock tailpipe. The join between the new mufflers and stock tailpipe is held together by a clamp. I didn't have any threads remaining to cinch it down, so I decided to look up a replacement clamp.
    I removed the clamp and junk on the left side of the photo to hopefully just replace it with the stainless clamp on the right. https://www.amazon.com/dp/B001P28WK2?ref=ppx_yo2_dt_b_product_details
    Am I missing some additional hardware or gasket? It seemed like I was about bottoming out on the threads with the new clamp before I even got close to tightening around the pipe.
    I backed off of it and am running it without a pipe after the muffler for now before I mess anything up. Will likely take it to an exhaust shop if there isn't an obvious part missing.
  2. Aug 17, 2021 at 12:34 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    New clamp shown on right is not a stock replacement, so could be too large for the pipe and not allow it to get tight enough. No idea.
    I do know the stock clamp works fine. I used the stock clamp when installing my DD exhaust- have no issues and no leaks.
  3. Aug 26, 2021 at 11:09 AM
    back_cast
    Denver, CO
    Hello. I need some help identifying an "after market" donut gasket for a 2018 tundra. The gasket needed to connect the pipe downstream of the muffler to the rest of the exhaust tubing. Has anyone ordered this before? Auto shop wants to charge me "$20-30 for the part and then an hour of labor"....they can get bent. There are other options on Amazon that would likely suffice.
    The spent piece looks like this.
  4. Aug 26, 2021 at 11:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I purchased the same clamp for the same location on my DD system. Worked perfectly. No gasket, but I did goop it up with some high temp RTV.
  5. Aug 26, 2021 at 11:18 AM
    frichco228
    Why not just buy OEM, they can't cost much. It will surely work and you will be done with it.
    GODZILLA likes this.
  6. Aug 26, 2021 at 11:20 AM
    back_cast
    Denver, CO
    Yeah, I probably will go that route. Ugh, what a frustrating component. The damn pipe wants to rotate as I install it.
  7. Aug 26, 2021 at 11:52 AM
    Shaken_1
    Shaken_1 New Member
    2015 TRD 4x4 OffRoad CrewMax
    I added a single chamber flowermaster and dumped mine ....no such issue lol
    back_cast[OP] likes this.
  8. Sep 29, 2021 at 7:09 AM
    back_cast
    Denver, CO
    DeesCrewMax, Nbab23, Hbjeff and 2 others like this.
  9. Oct 17, 2021 at 7:00 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    What size clamp did you use 2 3/4” or the 3” v band clamp for the tail pipe? The 2 1/2” would be too small correct…
  10. Oct 17, 2021 at 8:28 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The listing states that the one I bought is 2 3/4".
  11. Oct 17, 2021 at 10:38 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Nbab23 likes this.
  12. Feb 25, 2022 at 7:55 AM
    back_cast
    Denver, CO
    Clamps are garbage. Still kept slipping…went to a local exhaust shop and had them weld it for $40. Should have gone that route from the beginning.
  13. Feb 25, 2022 at 8:12 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I paid 40$ CDN replacing it buying it at a autopart store. There was no gasket. Just clamps on.
