Entune suddenly goes silent
Discussion in 'Audio & Video' started by lehminh, Mar 9, 2017.
  1. Mar 9, 2017 at 7:50 PM
    lehminh
    lehminh [OP] New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Anyone had this issue where Entune would go silent on the mode you are on during a ride? Occurred twice for me:
    1. Was listening to music via USB flash drive then lost all volume to the mode. Switch to Radio and had volume. Switched back but no volume from USB.
    2. The opposit happened where I was listening to radio and it siddenly cut out.
    Only two times do far. 2016 Tubdra with 7500 miles.
  2. Mar 10, 2017 at 8:06 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Normal unfortunately
  3. Mar 10, 2017 at 9:21 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    No, not normal. Take it to your dealer and report the issue. Its even better if you could get a video of it. They will report it to the technial regional rep and it gets escalated to engineering.
  4. Mar 10, 2017 at 10:01 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I have been updated 3 time SW wise and 1 time HW wise....shit still happens to me everyday.
    Do some searching around, seems to be a rather common occurrence.
    Best of luck and hopefully the already implemented "fixes" fix yours as they didn't mine...
  5. Mar 10, 2017 at 10:10 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    My entune unit on my 14' SR5 has frozen up about 3 times since I bought it new. I had to turn the truck off/on to fix it.
    Other than that, no issues.
    Just a thought, did you try hitting the mute button on the steering wheel to see if it would kick it off?
  6. Mar 10, 2017 at 10:11 AM
    lehminh
    Thanks for feedback, I will report issue to Toyota at 10k service.
  7. Mar 10, 2017 at 10:12 AM
    lehminh
    I'll try the mute next time it happens and report back.
    MotoTundra likes this.
  8. Mar 24, 2017 at 9:04 AM
    lehminh
    Here's a video of the issue:
  9. Mar 24, 2017 at 9:05 AM
    lehminh
    Hmm...can't seem to upload from camera. File compresses, I click close but no upload
  10. Mar 24, 2017 at 9:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    gotta upload to youtube then post.
    Law323, AnonVet and T-Rex266 like this.
  11. Mar 24, 2017 at 9:51 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I had this happen in my 2nd gen yesterday (non-Entune even). I was listening to radio, got a call, talked over bluetooth through truck speakers, hung up, and had no sound from the radio. I could switch stations and the frequency numbers would change so it didn't completely crash - just no sound. I could switch to XM and hear the basic channel info (I have no XM subscription) but had no AM or FM at all. Tried disconnecting my bluetooth, switching stations, etc. Had to stop and turn the truck off and back on to correct the issue.
  12. Mar 24, 2017 at 12:49 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Mine has actually reset during the middle of a trip. Playing music then shuts off and goes to the original startup screen and reboots. Luckily its not a factory reset since I still had all my presets but very strange. thought it was linked to towing a trailer but it did it afterward once already for the 3rd official time
  13. Apr 5, 2017 at 2:35 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Well my Entune is going nuts. It will shut off or freeze every 20 minutes??? Kinda gets old when radio and nav. both shut off and it reboots thus deleting my recent GPS location. Been traveling for work a lot and like those 2 features-probably a SW fix? Will find out next Thursday when I go to the stealership for SW and try and see if they will make some changes with Techstream (puddle light timer and seat belt chime) hopefully for FREE. got a bad feeling that a big bill is in my future...
  14. Apr 9, 2017 at 10:40 AM
    quarterhorse603
    quarterhorse603 New Member
    2016 1794 Edition
    While it isn't normal, it is by no means uncommon.
    In my '12 CM I used Sirius, so never got acquainted with the infamous Entune bugs. With my '16 1794, I've nothing but problems. After many software updates, the dealer finally replaced the head unit. Worked great for about 2 weeks, then went back to same performance as before. My service writer said it is a known problem.
    One day it hooks up and plays properly, and the next it won't connect. Usually, I can delete my phone from the unit, re pair and everything works great (for a while) then back to the same old problem. Some days my phone contacts load, some days they don't.
    I like to utilize Pandora, and while I can always get it to work with blue-tooth, it ought to work just as well with Entune.
