Engine won't run
Discussion in '2nd Gen Tundras (2007-2013)' started by doming, Sep 4, 2017.
  1. Sep 4, 2017 at 5:35 PM
    doming
    doming [OP] New Member
    2013 tundra 5.7 engine cranks but will not run. the 4x lites on instrument panel blink. I checked all relays . fuses,added gas, swapped battery .nada
  2. Sep 4, 2017 at 5:41 PM
    Any codes on it? Is it not receiving fuel?
    Mileage? Anything done to it?
  3. Sep 4, 2017 at 5:45 PM
    doming
    where will the codes show. the parts store said their tester would not show a code. the truck has 75000 mi.
    with first crank it seems to want fuel.
  4. Sep 4, 2017 at 5:49 PM
    Plug into OB2 port. Check for current and pending.
  5. Sep 4, 2017 at 6:07 PM
    doming
    I'll go to parts store and borrow tester and see what the test shows
    ColoradoTJ likes this.
  6. Sep 7, 2017 at 8:52 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Check your security indicator while cranking. If it's still lit or flashing, suspect the transponder in your key.
    NewImprovedRon likes this.
  7. Sep 8, 2017 at 7:35 AM
    doming
    engine started. I was checking why horn didn't blow and switched fuses . happened to be the fuse for the ignition. replaced it and all is fine. at age 80 some of us forget a few things. thanks guys for all your help.
    Bprose, NewImprovedRon and T-Rex266 like this.
