engine sounds like diesel after belt and water pump change
Discussion in '1st Gen Tundras (2000-2006)' started by Prinnzze, Apr 22, 2020.
  1. Apr 22, 2020 at 8:16 PM
    Prinnzze
    Prinnzze [OP] New Member
    Charlie
    none
    starts and runs but does not race out fully
  2. Apr 22, 2020 at 9:03 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Is the timing setup correctly? Sounds like the belt is off a tooth or two?
    who did the timing belt?
  3. Apr 22, 2020 at 9:04 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Lots more info needed about what you did before anyone here can diagnose it. Year of truck, size of engine,....what exactly was done to it? Lots of smart people here who can help you if you can explain it better to them. Good luck.
  4. Apr 29, 2020 at 7:38 AM
    Twest130
    Twest130 New Member
    Travis
    2000 sr5
    with out looking at it sounds like its out of time. Id also look at the hydrostatic tensioner
