Engine shut off while driving...wont restart
Discussion in '2.5 Gen Tundras (2014-2021)' started by KrokemOutdoors, Jun 19, 2019.
  1. Jun 20, 2019 at 11:15 AM
    InfernoTundra
    InfernoTundra New Member
    I didn't watch the video with sound, so did the truck turn over when it died and just wouldn't start?
  2. Jun 20, 2019 at 11:16 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I was just gonna ask the folks here about this. This has happened each time I disconnect the battery as well. Then no issue. Also did it when I replaced with a new battery. I assume this is supposed to happen but don't know why.
  3. Jun 20, 2019 at 11:17 AM
    KrokemOutdoors
    KrokemOutdoors [OP] Driver
    Edward
    2019 MGM tundra limited Trd offroad
    Luckily, the forest road wasn't too dusty !
    landphil[QUOTED] likes this.
  4. Jun 20, 2019 at 11:17 AM
    KrokemOutdoors
    Edward
    The truck would start when I turned the ignition key, but would shut down immediately after.
  5. Jun 20, 2019 at 11:19 AM
    InfernoTundra
    Ah note to self, turn on the sound.
  6. Jun 20, 2019 at 11:24 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Interesting, I’ve been speeding in the desert here in bumfuck CA many times in whoops and oh shit moments where I thought something broke and never had that happen, glad it worked out for you and it was nothing serious.
    KrokemOutdoors[OP] likes this.
  7. Jun 20, 2019 at 11:25 AM
    KrokemOutdoors
    Edward
    Thanks. I just didnt do a great job of tightening the clamp for the intake hose and throttle body connector. I made sure I gave it some extra elbow grease this time around!
    Samoan Thor[QUOTED] likes this.
  8. Jun 20, 2019 at 11:40 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Same exact thing with mine. What’s interesting is that the last time I worked on my truck, I connected the battery terminal and then waited approx 10 mins to start it. And it did start the first time..
  9. Jun 20, 2019 at 11:46 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    This is the best forum ever. Never would have thought about the that. Glad you got ur truck fixed.
  10. Jun 20, 2019 at 11:59 AM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Glad you were able to figure it out
  11. Jun 20, 2019 at 12:00 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Sweet!! I was just taking a wag based on my experience with my junky gmc. I think its pretty rare to have problems with the Tundra.
  12. Jun 20, 2019 at 12:59 PM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Good that is was a quick, easy and free fix.
    A little bothersome that something like that will keep it from running.
  13. Jun 20, 2019 at 1:48 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The mind runs crazy with possibilities had the dealership gotten the truck into their shop, found the mega easy fix and then.................what they might have told the OP the problem is/was and what the cost is.
    KrokemOutdoors[OP] and 15whtrd like this.
  14. Jun 20, 2019 at 2:30 PM
    KrokemOutdoors
    Edward
    Yeah, I wasn't gonna stick around for that!
    15whtrd likes this.
  15. Feb 26, 2020 at 6:25 PM
    ScruffyJones
    ScruffyJones New Member
    07 Tundra Crewmax Limited
    Hey y'all I have an '07 I'm driving and it's been doing this same thing... I'll get maybe a block down the road and the engine will just shut off and wont start back up... I've tried cleaning the throttle body and making sure all hoses are tight but the problem is persisting. When I hook it up to the computer it get zero codes... I've seen videos where it could be a connection on the fuel tank where a wire connection is messing with the fuel pump but I'm at a loss here... need suggestions badly...
  16. Feb 28, 2020 at 3:58 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    That sounds like a bad fuel pump to me. I once had an MR2 that did the exact same thing. Will run for a little bit and then the pump heats up and stalls.
  17. Feb 28, 2020 at 6:21 AM
    blanchard7684
    blanchard7684 New Member
    awesome thread.
    I was like awwww crap the fuel pump issue finally actually got to someone in the wild.
    lol...nope.
  18. Feb 28, 2020 at 8:07 AM
    ScruffyJones
    I got it to run for most of the day yesterday, I changed the oil and cleaned the engine to try to get some of the sensors cleaned up a bit. It seemed to run fine all day and now this morning once leaving work it just died died.. would run for 20 secs and then die again... could it be an alternator issue?
  19. Feb 28, 2020 at 8:15 AM
    #49
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    There is a current recall for fuel pump issues. We received our notice last week and Toyota is working on a solution ‍♂️
  20. Feb 28, 2020 at 8:17 AM
    #50
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Better not run than suck in insurmountable amounts of dust and dirt, am I right?
  21. Feb 28, 2020 at 8:19 AM
    #51
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I don't think it is supposed to happen. I just replaced my stock Toyota battery with an Interstate battery. Cranked right after with no problems nor any problems since.
  22. Mar 2, 2020 at 12:32 PM
    #52
    ScruffyJones
    So i caved and took it to a dealership.... they're saying its the battery but honestly I dont think that's true... they said the terminals were corded but I had just changed them before I brought it in... they said it runs fine but I'm looking at 120 miles back home....
  23. Mar 2, 2020 at 12:56 PM
    #53
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Ask them if they will pick you up if they say it wont break down and it does.
  24. Mar 2, 2020 at 1:59 PM
    #54
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    That is a huge vacuum leak. Bet there are some MAF codes in the ecu. Glad you caught it.
  25. Mar 4, 2020 at 12:10 PM
    #55
    ScruffyJones
    I went today and picked the truck up from the service guys and it died right out the door.. I had a ride take me the 120 miles there so I definitely needed a loner car back... well now they're going to look at it again... this is just getting old
  26. Mar 4, 2020 at 12:33 PM
    #56
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
  27. Mar 4, 2020 at 12:43 PM
    #57
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I can't believe the ball was dropped
