Engine shaking while driving.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Migue02, Sep 11, 2023.
  1. Sep 12, 2023 at 5:07 PM
    Migue02
    Migue02 [OP] New Member
    Miguel
    2017 silver tundra limited
    None-for now
    I’ve erased them with the scanner and they keep popping up now. Speaking with a mechanic he’s suggesting injectors.
  2. Sep 12, 2023 at 5:31 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    That's a pretty extreme jump imo. I would get all new coils before committing to that
  3. Sep 12, 2023 at 5:39 PM
    AZBoatHauler
    So.Arizona
    I’d verify it isn’t a broken valve spring. You should get a dtc indicating a bad injector if that’s what’s happening.
  4. Sep 12, 2023 at 5:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does sound logical though. OP has already swapped coils and the misfire remains at the same cylinder. If he were able to swap two injectors, that may shed some light. Irritatingly, the passenger side of the engine is a little more difficult to pull the injectors.
  5. Sep 12, 2023 at 5:41 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds reasonable, if it's within the OP's skillset. There is kind of a lot of shit to get out of the way though. LOL
  6. Sep 12, 2023 at 5:46 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Was thinking fuel/injectors too. Might try some sea foam in the gas, check the fuel injector wires too.
    Wynnded likes this.
  7. Sep 12, 2023 at 6:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It sounds like they've swapped 2 and 4 and the miss remains at #2. But no, no new coils so far.
  8. Sep 12, 2023 at 7:46 PM
    Migue02
    Miguel
    None-for now
    Mechanic is coming out Saturday. I just don’t have the knowledge and tools to check injectors, valve spring, or a vacuum leak. He said he has a spare new coil he can test to make sure and look over what I did but that he wants to check the injectors next if that doesn’t seem to fix it.
    Wynnded likes this.
  9. Sep 12, 2023 at 9:30 PM
    Migue02
    Miguel
    None-for now
    Would you guys pay for a compression check? He says he would rather do that first. The thing is he said with doing that he will have to charge me for the plug re install too.
  10. Sep 13, 2023 at 12:02 AM
    AZBoatHauler
    So.Arizona
    Probably a good place to start. If compression is the same it’s probably a fuel issue. If low a problem with a valve or worse.
  11. Sep 13, 2023 at 5:03 AM
    MadMaxCanon
    Yeah, a compression test is actually not that expensive to do. If you really wanted to go cheap, you can buy a kit from harbor freight for about 40 bucks. I have used it before its actually decent quality.
    KNABORES likes this.
  12. Sep 13, 2023 at 6:32 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    You can rent/loan a compression tester at Autozone or O’Reilly.
    MadMaxCanon likes this.
  13. Sep 13, 2023 at 6:44 PM
    Migue02
    Miguel
    None-for now
    He was able to narrow it down to a fuel injector. Is there a brand you guys recommend.
    Wynnded likes this.
  14. Sep 13, 2023 at 6:53 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I think best bet are the OEM Denso ones, if I’m not mistaken. It may be possible to replace just one if OEM but I think most will recommend to do all 8 so their matched and same condition.
