Engine or axle jump
Discussion in 'General Tundra Discussion' started by Law323, Jan 1, 2017.
  1. Jan 1, 2017 at 12:17 PM
    Law323
    Law323 [OP] it’s only weird if you make it weird
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    This has only happened three times in the past couple months.
    I'll let my truck warm up for no more than a minute before driving off. Sometimes within a mile later, I'll be at a stop light/sign full stop and I'll press the accelerator. It revs up slightly for a couple seconds and "catches" putting me in second gear pretty rough. I never punch it, it's always a slight acceleration.
    Any idea what this is? I'm thinking it's either the cold weather or need some new rear axle oil. (Changed that 6 months ago at the 50k milestone.
  2. Jan 1, 2017 at 12:31 PM
    Did you do your 30k mile service in the Transmission? All this is:
    Level & viscosity check
    All solenoids checked for function.
    Sounds to me, if the engine revs up and goes hard into the next gear...solenoid issue.
    My dealership did my 30k check for free, did the 60k mile service (drain and fill) plus check all the solenoids.
    I was going to do a drain and fill at 90k, but we know why I didn't perform that service.
  3. Jan 1, 2017 at 12:32 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep. Sure did. @ColoradoTJ
    Didn't get them to check the solenoid though.
  4. Jan 1, 2017 at 12:34 PM
    They should have checked them.
  5. Jan 1, 2017 at 12:41 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'll get them to check it when I bring it in for an oil change. Getting one soon
    NewImprovedRon likes this.
  6. Jan 1, 2017 at 1:17 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Doesn't it really matter that it only happens rarely (three times in the pst couple of months) and only has happened now that it's been near freezing temps? Still sound like a solenoid going bad?
  7. Jan 1, 2017 at 1:28 PM
    Solenoids can stick due to temps. That is three more times than mine did in 84k miles.
    Could be something else as well doing on in the transmission. They may put a recorder on your ecm to troubleshoot what is going on.
    Law323[QUOTED][OP] likes this.
  8. Jan 1, 2017 at 1:30 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Good deal. Good thing my trucks still under warranty! LOL
    NewImprovedRon and ColoradoTJ like this.
  9. Jan 1, 2017 at 1:32 PM
    Hell yes brother. Better to break now than later.
    Once you get it on record, it helps with warranty issues after the 60k or if you have 100k miles.
  10. Jan 1, 2017 at 1:35 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I believe I have something similar to this. Only in cold temps before warming up.
    Law323[OP] likes this.
  11. Jan 1, 2017 at 1:38 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'll have to make a point to have the camera running just in case it happens again, for proof that is.
  12. Jan 1, 2017 at 1:39 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Maybe I need to warm the truck up a bit longer than 30 seconds. I'll try that
    NewImprovedRon and 040Tundra like this.
  13. Jan 1, 2017 at 2:39 PM
    csuviper
    Broomfield, CO
    Engine won't really warm up the tranny that much. Better to move.
