Engine Noise
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kbar691, Nov 27, 2020.
  1. Nov 27, 2020 at 11:23 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Got a question. When I start my 2019 I hear clicking/tapping from the engine. Doesn’t do it if you shut off and restart. I don’t recall this in my 2013 TSS. Does anyone else have the same thing?
  2. Nov 27, 2020 at 11:28 AM
    lloydb82
    lloydb82 New Member
    Lloyd
    2021 tundra limited crewmax
    Mine was doing the same thing. Toke it to dealership and pickup 3 days later and said nothing was wrong with it. Traded it in shortly after but if you search the website and youtube it seems to be the driver side top timing chain tensioner. The noise you hear is the timing chain tensioner guide. Usually made the noise when below 28 degrees. After it warmed up it goes away.
    Kbar691[QUOTED][OP] likes this.
  3. Nov 27, 2020 at 11:49 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Hmm. That is interesting. I live in Houston and I can nearly count the minutes on one hand that it has been under 28 degrees. Haha. I will have to search and see if it is a problem or just a noise. If there is no issue then I won’t worry too much.
  4. Nov 27, 2020 at 1:17 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    My 2019 PRO does the same thing. I treat it like a sore dick and a rattlesnake and don't F**K with it. The truck is under warranty. Drive it like you stole it. Party On.
  5. Nov 27, 2020 at 5:02 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I use to hear that but when I checked my oil level it was a little low, and when i topped it up never heard it again. :thumbsup: I would check it out and see if that’s the case wouldn’t hurt.
