engine light
Discussion in 'General Tundra Discussion' started by conman, May 11, 2019.
  1. May 11, 2019 at 6:53 AM
    conman
    conman [OP] New Member
    2019 tundra 1794 engine light on dealer replaced hose and emission box, light came on again after 3 days
    waiting to hear back from toyota any ideas thanks
    Dealer just said toyota thinks wiring problem now want it back for couple of days to test wires?
  2. May 11, 2019 at 7:36 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    First off.. Welcome.
    Secondly, the dealership is alleging that your Tundra out of the entire assembly line got your wires installed wrong? Lol.
    Are we talking about the vapor canister? Those lines can break I suppose.. Takes 5 minutes to fix. Air injection check valve?
    Do we have a code to work with? Nobody needs a truck for a few days to troubleshoot this. Testing wires? Lol.
    I'm sorry. I know it's warranty and your stuck at the dealer, but you might consider elevating this to a shop manager. Sounds like someone needs a swift kick in the ass.
    What dealership is this?
    T-Rex266 and Black Wolf like this.
  3. May 12, 2019 at 9:31 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Sent you a PM.. Hang in there brother.. Easy fix. Truck will likely outlive you.
    I know I recommended the evap canister and it's affiliated lines.. Is that the evap box? Pump and its lines? P2400
    Black Wolf likes this.
  4. May 12, 2019 at 10:06 AM
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    My check engine light is on what does this mean on my 2007 Toyota tundra pickup truck!
  5. May 12, 2019 at 10:13 AM
    You need to get the code read
  6. May 12, 2019 at 11:11 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Hi Tierhog, codes that show up on 2019 tundra 1794
    P043E
    P043F
    P2401 evap emission system leak detection control circuit low
    P2402 pump control circuit high
    P2419
  7. May 12, 2019 at 11:12 AM
    Tierhog
    Tierhog SIG-AHOLIC
    There are a few different reasons why P2400 would set:
    • The most obvious would be that the leak detection pump motor has failed. A failure of the pump motor could cause an open or short circuit in the leak detection pump control circuit.
    • Next would be a leak or damage to the hoses that connect the pump to the EVAP system. This would cause a condition where the pump control circuit would be good, but the computer does not see the right reaction from the system.
    • The final problem could be with the wiring or the ECM itself.
    In short, it seems your evap canister is toast, or the hoses to and from that relay information to your ECM.
    You may have over filled your tank and damaged your canister, bad line, snagged or damaged line, etc.
    I'd focus on the lines into your evap canister and if not remedied, the canister itself, clear codes and wait.
    Since it's under warranty, push them into the evap category, not the 1000 miles of wiring the factory installed.
  8. May 22, 2019 at 1:07 PM
    conman
    Update: dealer put on new canister, still no change, they contacted Toyota and were told it is a electrical issue as previous parts did not work, dealer checked all pins as Toyota instructed and light still on, now Toyota says they will have to start on wiring
