Engine failure
Discussion in '3rd Gen Tundras (2022+)' started by Cjonez1993, May 19, 2023.
  1. Jul 22, 2023 at 2:55 PM
    #151
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I’m not saying that you don’t have a problem, but my truck had a very similar clunk for a full year until Toyota released a TSB for it. It sounds like the startup “clunk” a lot of trucks had for a long time.
    You might check to make sure they flashed your TCM with that software update that was referenced in T-SB-0110-22. It’s possible that the TCM was set back to its original software during the rebuild or maybe that TSB was never done in the first place. Just a thought.
    Kap1 and Mattedfred like this.
  2. Jul 22, 2023 at 3:36 PM
    #152
    Cjonez1993
    Cjonez1993 [OP] New Member
    2022 tundra trd
    So your telling me the special engineer/tech toyota specifically flew out to look at my truck does not know common problems/fixes for current engine related noises?
    If this is a common (because of the software update is needed) but fixable issue and him and the store did not program my computer to relieve me of this clunk and my current issue makes me believe the issue is not software related and toyota is just not wanting to rebuild another engine that is still "running"
    Again I appreciate the information you sent me and I would consider passing that on if I actually wanted this truck. The only thing the dealer and Toyota has done for me that I appreciate is get me into a truck so I can continue my work. Even if it was 5 different trucks because they kept putting me in new ones and they kept selling them while I was in them.
    Leo's first likes this.
  3. Jul 22, 2023 at 6:21 PM
    #153
    Kap1
    Kap1 New Member
    San Francisco, CA
    We don't know what the special Toyota tech did, but this clunk sounds the same as the "startup clunk" that my truck had until the TSB was released for it, I think it was related to the transmission. It's no longer doing this clunk sound at the start up, however, when I have my rear window down, I can still hear this clunk once a week or so when driving, when transmission is getting into weird shifting situation...
    So ask dealer to check the clunk tsb that's referenced above, it may fix it as it did for all of us
  4. Jul 22, 2023 at 6:56 PM
    #154
    Imagine how embarrassing it would be to rebuild a motor for a transmission problem?
  5. Jul 22, 2023 at 8:11 PM
    #155
    KroppDuster
    Bilstein 5100s
    Correlation does not imply causation, as the saying goes. It’s possible the two events have nothing to do with each other.
    That being said, it would suck if trucks with the start up “clunk” were indicative of the ones with a highest likelihood of engine failure.
    Kap1 likes this.
  6. Jul 23, 2023 at 11:51 AM
    #156
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    I could show you a video of mine doing the exact same thing or you could just watch your own again, mine is even the same color. Fixed in 50min at the dealership with the T-SB-0110-22, not only did it fix that, but the truck drives completely different now...in a good way.
    SC4333, Mattedfred and Leo's first like this.
  7. Jul 23, 2023 at 12:53 PM
    #157
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Kap1 likes this.
  8. Jul 16, 2024 at 6:14 AM
    #158
    JCT3N
    JCT3N New Member
    hey. Wanted to see your you have an update given another year has passed? Still have the truck? still have problems?
  9. Aug 9, 2024 at 8:28 AM
    #159
    owenskp
    owenskp New Member
    Kevin
    2022 Tundra Limited 6.5 Bed Supersonic Red
    I have a '23 non-hybrid Platinum with a build date of Jan 17, 2023. It has not been included in the recall. The dealership told me yesterday that my engine was produced at a plant that did not have engine problems. I am only aware of these engines being produced at the Huntsville plant. Was the dealership giving me a BS answer to blow me off?
  10. Aug 9, 2024 at 8:33 AM
    #160
    Breathing Borla
    AZ
    yes, there is only one plant for USA tundras
    just lying to you to try and calm you down
