ENGINE DIED AT 160K????
Discussion in '2.5 Gen Tundras (2014-2021)' started by JusCookin4u, Jun 22, 2022.
  1. Jun 24, 2022 at 6:55 AM
    Trailbreaker
    Trailbreaker New Member
    Rick
    2021 Silver 1794 4x4 OR
    I am sure the engine is rebuildable, but with the volume they see in the dealership it will likely be sent off to a shop that is better set up for it. Your engine will just become part of that rotation. Well, if they are being honest about the repair anyway ...
    I put about 190k miles on my Tacoma on Wawa gas about 30 minutes north of you in Burlington. I have always heard it was not the greatest, but never experienced it first hand.
    Ugh, sorry you have to deal with this so early in its life.
  2. Jun 24, 2022 at 7:04 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Don't cases like this often start with no support tube in the oil filter cap? Someone yanks it with the filter, new filter collapses sometime afterwards, and boom out of the blue. Something to check.
  3. Jun 24, 2022 at 7:25 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    https://youtu.be/Y1En6FKd5Pk
    landphil[QUOTED] likes this.
  4. Jun 24, 2022 at 7:59 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Mine went at 190k. Quotes from dealer for new engine $37k. Lol. Had an independent shop rebuild for 13k. A used engine, or rebuilt was first choice but none available.
  5. Jun 24, 2022 at 12:08 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  6. Jun 24, 2022 at 12:20 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Truck is not worth new engine or rebuilt engine. Was a compression test taken? Leakdown test? My lexus pinged, continuously for 12K miles. I didn't care and zero damage to engine for 12,000 miles. I finally found the problem to be a hole in the air box resonator after the MAF sensor which caused the engine to run lean. Again 12,000 pinging miles and no damage. Do not attempt to tell me one bad tank of gas caused damage, lmao...
    Retired...finally likes this.
  7. Jun 24, 2022 at 12:21 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    Sorry for your misfortune. If it is bad, I personally would take the engine that you found. Good price and good mileage. Keep us posted.?
    Luckydog likes this.
