Engine code P0101
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeff07, Nov 12, 2019.
  1. Nov 12, 2019 at 9:17 AM
    Jeff07
    Jeff07 [OP] New Member
    Jeff
    07 Tundra 4.0
    Hello everyone! New to the board and I'm struggling with an engine code and could use any help! I have a 2007 Tundra 4.0 V6 and have Been dealing with P0101. This is what I have done so far:
    Replaced MAF
    Replaced PCV valve
    replaced hose clamps that were loose
    cleaned air filter, box, hose and all related parts
    cleaned throttle body
    CEL is still on. Ive also seen where this could be EGR problems, MAP sensor, and or Cat converter problems.
    Im not sure my engine has a MAP and I don't think its converter problems. I think its got to be EGR or possible manifold gasket leaks. Any help would be greatly appreciated!!
    Thanks
  2. Nov 12, 2019 at 12:58 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Cleaning the MAF sensor with MAF cleaner always works for me to clear that code.
    P-Factor likes this.
  3. Nov 18, 2019 at 6:31 AM
    Jeff07
    Jeff
    07 Tundra 4.0
    Tried both of those this weekend. Ill keep going down the list...
  4. Nov 18, 2019 at 6:44 AM
    P-Factor
    P-Factor New Member
