Engine Bay Cleaning
Discussion in 'Detailing' started by Kbar691, Mar 29, 2023.
  1. Mar 29, 2023 at 9:34 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Crazy to say this but I have never in my life cleaned the engine bay of any vehicle. I want to add this to my agenda of keeping my Tundra clean. Any of y’all do this and anything for me to watch out for? TIA.
  2. Mar 29, 2023 at 10:00 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I do mine frequently. Citrus based engine degreaser and don't water spray directly on to fuse block. Easy
    mtucker and Kbar691[OP] like this.
  3. Mar 29, 2023 at 10:15 AM
    Goofinator
    Goofinator New Member
    Bernard
    Yeah don’t use high pressure just normal water hose cover anything up that might be to sensitive and I do it with a cold engine to avoid cracking the block
    Kbar691[OP] likes this.
  4. Mar 29, 2023 at 12:03 PM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    Bucket of Hot Water, Simple Green, and some good strong Microfiber Cloths.
    Mix the Simple Green in the Hot Water Bucket, toss-in the cleaning cloth, remove cloth and wring it out. Wipe areas with cloth. When cloths get dirty, toss it back in the bucket and wring it out and repeat. When cleaning water gets too dirty, dump it and mix up another batch. Start with the under side of the hood and work your way down into the Engine Bay. To detail components in the Engine Bay, use some Vinyl and Rubber Protectant on the plastics and the rubber hoses. I like Adams VRT for this. It is not sticky and doesn't attract and hold dirt/dust.
    I'm not real keen on spraying water (hose) into an Engine Bay.
  5. Mar 29, 2023 at 12:20 PM
    Retired...finally
    I have less than fond memories of a small underhood fire the morning my Dad started the 59 Fury to head to California from Ohio. The day before he washed the engine bay.
    Kbar691[OP] and Demented Canine like this.
  6. Mar 29, 2023 at 3:49 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    I have always been a little nervous to spray water around all the electrical stuff!
  7. Mar 31, 2023 at 11:00 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I go straight to the car wash bay and turn it on presoak if they have that option...spray it on trying to avoid fuse box and wiring on that side...let it soak and then use low pressure spot free setting to rinse. Works pretty well and never a problem.
    Kbar691[OP], 1lowlife and dondino like this.
  8. May 3, 2024 at 8:21 PM
    catdawg
    catdawg New Member
    2017 SR5 5.7L Double Cab 4x4 Quicksand
    Bilstein Level Kit w/ 285/70/18 Nitto Grapplers on Factory Wheels. TRD Cat Back Dual Exhaust System.
    On other vehicles I usually spray a heavy coat of diluted Simple Green all over everything, let sit for a few and then use a hose with nozzle to rinse carefully with a heavy mist, avoiding the coils. Then wipe dry everything I can get to with rags. I damaged coils on a f150 once using way too much water and it was an expensive mistake. I haven't cleaned my '17 SR5 5.7 yet. The coils are right out in the open and will be difficult to avoid, but they look like they're sealed. Just wondering if a light water spray would damage them. Doing the LED headlamp upgrade this weekend so I want to clean everything under the hood while I'm in there.
  9. May 3, 2024 at 8:57 PM
    Most modern cars you can spray down. Just keep the nozzle moving with less pressure. If there’s an open air intake- cover it. I also cover any wires I see around
