Engaging 4wd regularly... I have never done this
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundrathr0w, Oct 26, 2019.
  1. Oct 27, 2019 at 3:21 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    You'll likely get more than pavement, but make a turn on hard packed dirt in 4WD and see if the truck doesn't buck a little.
    GODZILLA likes this.
  2. Oct 27, 2019 at 4:32 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Just plan to get on the dirt once a month and explore some outdoor areas. Good to go after that.
    Pinay likes this.
  3. Oct 27, 2019 at 4:47 PM
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    right, you can turn in 4hi just fine, but long turns, like getting on a freeway interchange on dry pavement might not be the best. As much as I'm not ready for the snow, I'm ready for the snow.
  4. Oct 27, 2019 at 5:06 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I probably use 4wd about 5-6 times a month, every month to get to my hunting and fishing spots. The farmers let me drive through their land and some of the roads are really muddy leading into the areas. But, no way do I hit the 5-10 miles.
  5. Oct 27, 2019 at 5:13 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I turn mine on every once in a while when I think about it. More of just turning it on and off a couple times, maybe drive 1/4 mile with it engaged. I notice if I haven't engaged it in a while, it takes a little bit to get it to engage. The more you turn it on and off, the quicker it engages. Usually make sure to engage it a couple times before hunting season and before they are predicting snow just to make sure it will engage quickly when needed.
    Rebel Tundra Man and 15whtrd like this.
  6. Oct 27, 2019 at 6:40 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    ..it ain't easy being beautiful...
  7. Oct 27, 2019 at 6:43 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    True that. Lol
    15whtrd likes this.
  8. Oct 29, 2019 at 12:43 PM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    That is always the good thing about my Tacoma. manual transmission, with a stick and linkage 4wd. mash the clutch grab the lever and pull, goes in every time. I think the book recommends not to drop it in above 55mph but handles great on about any surface once its engaged and haven't had any issues at up to about 75mph either with 4-hi engaged.
    NewImprovedRon likes this.
  9. Oct 29, 2019 at 5:58 PM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I don’t get what you guys are saying. Does 4wd not work properly? 4wds have been on the road for eons.
  10. Oct 29, 2019 at 6:24 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    When you go around a turn each tire is taking a different track and going a different distance so they are spinning at different speeds. When you are in 4wd, it locks some of the wheels together so if you are trying to turn while in 4wd one of those tires has to be able to slip, when on pavement, you have too much traction and the tires aren't able to slip so it's possible you can break something or at least bind it up and put a lot of pressure on the drivetrain.
    NewImprovedRon, T-Rex266 and 15whtrd like this.
  11. Oct 29, 2019 at 6:31 PM
    15whtrd
    15whtrd Mr. Blonde
    jpod[QUOTED] and NewImprovedRon like this.
  12. Oct 29, 2019 at 6:44 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I understand the need to use the 4WD occasionally to keep everything nice and lubricated, but i think Toyota's 10 miles per Month might be a little overkill on their part. :goingcrazy:
    Glockmeister, PA452 and Haggis777 like this.
  13. Oct 29, 2019 at 8:25 PM
    PA452
    PA452 New Member
    Agreed. And what I don't like about it is it's leading people to believe, "well if Toyota wants me to drive ten miles in 4WD monthly, surely that must mean it's OK to do that on pavement".
    TILLY[QUOTED] likes this.
  14. Oct 29, 2019 at 8:31 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I'm often wrong [which never fazes me], but I'm calling B.S. on this 'shift into 4-wheel drive once a month for 10 miles' crap.
    I never do it. Call me a thrill seeker who likes to live dangerously.:quickdraw:
    Glockmeister and TILLY like this.
  15. Oct 29, 2019 at 8:55 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    soo I'm guessing the whole 5 times I've been in 4wd over the life of my tundy equals bad
    TundraDude18 and TILLY like this.
  16. Oct 29, 2019 at 8:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I only do it if it’s on highway, not even local.
    TILLY likes this.
  17. Oct 30, 2019 at 8:54 AM
    mikey281
    mikey281 New Member
    mike
    dirt road in Aptos
    2018 TRD OFF ROAD 4x4 CM Cement
    zip
    Use mine every time I drive my Tundra, I live 1/4 mile up a crappy dirt road off the pavement. Never had a problem. Same with my '96 4runner, never a problem.
  18. Oct 30, 2019 at 9:01 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I do it on the odd straight away or gravel road I'm driving down.
    I'll be using it regularly for the next 6months....we get snow for about 6 months a year. :eek2:
  19. Oct 30, 2019 at 9:22 AM
    #49
    jpod
    London Canada
    I thought that was what the diff locks were for? What do they have both for?
  20. Oct 30, 2019 at 9:54 AM
    #50
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    tundra don't have diff lock, the main problem is we missing a central diff, a third diff that change the differences between the front and rear
    https://youtu.be/mhTVQh7bFtw
    jpod likes this.
  21. Oct 30, 2019 at 5:25 PM
    #51
    TundraDude18
    'Merica
    '21 Limited CM
    Yeah, I know already. My point was that I don't think it is necessary and am not going to do it.:D
  22. Oct 31, 2019 at 9:44 AM
    #52
    jpod
    London Canada
    That seems like a flaw to me...
  23. Oct 31, 2019 at 10:25 AM
    #53
    PA452
    PA452 New Member
    No, it's just the nature of 4WD. This isn't AWD.
    BravoDeltaRomeo and 15whtrd like this.
  24. Oct 31, 2019 at 10:31 AM
    #54
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    you guys have me totally freaked out. screw it. i'm selling the tundra, turning in my truck gang card and buying a ridgeline...
    BravoDeltaRomeo and BeachyTundra like this.
  25. Oct 31, 2019 at 3:22 PM
    #55
    TundraDude18
    'Merica
    '21 Limited CM
  26. Oct 31, 2019 at 3:29 PM
    #56
    Professional Hand Model
    Hand Protectors
    Go about 3 years without using it like I did due to not ever needing it and then wonder why the actuator sticks and doesn’t engage when you finally do need it (like I did). It took a few attempts to shake the cob webs off and finally get it working again.
    NewImprovedRon and 15whtrd like this.
  27. Oct 31, 2019 at 3:44 PM
    #57
    TundraDude18
    'Merica
    '21 Limited CM
    In a moment of independence, I made a shockingly inappropriate comment, which was really just shtick [a 'bit' or character sketch] where I get to be a young dude living in the early 80's again, foolish, wild, and free.
    I repent. The manual is correct. I will shift into 4-wheel drive more often [at least]. I apologize for misleading the forum, and it IS good to know that this is a serious issue deserving of my real attention.
    I am in 4-wheel drive now.
    --Bit Over--
    That story does drive the point home, though: thanks for telling me; I actually will shift into 4-wheel drive occasionally now. I can only go about 9-10 months without using it where I live. BUT ... I DO want my 4-wheel drive to work.:thumbsup:
    P.S. This is probably the only time in my life that I am going to take advice from a professional hand model.:monocle:
