Enclosed Utility Trailer Leaf Springs
Discussion in 'Towing & Hauling' started by Skywind, Jun 19, 2023.
  1. Jun 19, 2023 at 5:33 AM
    Skywind
    Skywind [OP] New Member
    Hello everyone,
    Where do you recommend to order leaf springs for utility trailers. One of the layers on the leaf spring broke and I plan to replace both sides. 3500lb axle. Any tips and advice you may have please feel free to share! Much appreciated!!
  2. Jun 19, 2023 at 5:44 AM
    I have used etrailer.com or just the local trailer parts/sales dealership. Assuming you don't have one close to you, I would just order online. Springs and hardware.
    Tractor supply has some pretty good selections too.
    RichterScale and JCBerb like this.
  3. Jun 19, 2023 at 5:55 AM
    Skywind
    I appreciate the info!
    ColoradoTJ likes this.
  4. Jun 19, 2023 at 6:07 AM
    Anytime and welcome to the site. Axle still good?
  5. Jun 19, 2023 at 6:23 PM
    Skywind
    Axle seems to be good, 3500lb single axle. Seems simple enough to change out. I’m thinking I will grease the bearings and change the drum brakes in the near future as well. Do you work on trailers often?
  6. Jun 19, 2023 at 7:07 PM
    If the axle looks good and has a good arch still (spindles are not bent from overloading), a spring swap is pretty easy if you have all new hardware. Look for uneven tire wear, that is the first sign of bent axle or spindle. It isn't rare to break a spring, just something to look out for.
    https://trailerparts.com/products/springs.html
    https://www.etrailer.com/Trailer-Leaf-Springs/etrailer/e97SR.html
    I have worked on my fair share of trailers when I had light duty (7K) trailers.
    Skywind[QUOTED][OP] likes this.
  7. Jun 19, 2023 at 7:28 PM
    Overloading weight consistently will break a leaf spring.....my neighbor found that out the hard way.
  8. Jun 20, 2023 at 6:45 AM
    Skywind
    Great info, I’m thinking I’ll order a set today. Neighbor who has experience with trailers will lend a hand. Thankful for good neighbors. The trailer it self was in pretty new condition when I bought it 2 summers ago.
    Enclosed 2016 model 7x12 3500lb single axle with about 1500 miles on it. Since then I’ve probably put 12k miles on it. I would estimate the load I usually haul is no more than 1300lbs
