Electrical switch question
Discussion in 'Home Improvement' started by Hbjeff, Mar 4, 2020.
  1. Mar 4, 2020 at 9:58 AM
    Hbjeff
    Hbjeff [OP] New Member
    Huntington Beach
    2010 DC 5.7 2wd
    for you that know electrical, is what i am after possible:
    Current- bathroom has single switch that turns on fan and wall light.
    I don’t remember why the electrician tied them to the same switch. Maybe lazyness?
    Can i get them on separate switches easily, even if the light must be on in order to power the fan switch?
  2. Mar 4, 2020 at 10:03 AM
    coTony
    Tony
    Montrose, CO
    They normally put them on the same switch because when the light is on the fan is forced to run to eliminate the humidity.
    Can you do it? Yes
    Can you do it easily? Depends on how the wires are connected and routed
    NewImprovedRon and SIXSEVENONE like this.
