Electrical question
Discussion in '1st Gen Tundras (2000-2006)' started by Larry6464, Mar 23, 2021.
  1. Mar 23, 2021 at 1:37 AM
    Larry6464
    Larry6464 [OP] New Member
    Larry
    2002 Toyota tundra
    I have a 2002 Toyota tundra sr5. I have lights under tailgate , lights over step side, getting ready to add roof top clearance lights, and gonna add two 15" turn signal/ clearance lights on front. All lights are led's. Do you think I should change the fuse and upgrade to a 5 amp more type fuse. Any advise appreciated.
  2. Mar 23, 2021 at 3:32 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Absolutely not. The fuse is rated for the wire gauge that's in place.
    Those LEDs likely won't draw enough to make a difference.
  3. Mar 23, 2021 at 4:14 AM
    Professional Hand Model
    Hand Protectors
    Good thing about LED’s is they draw less amps by a significant ratio. You can add a ton more LED lights and still stay under the Fuzes Amp Rating. Your truck engine/alternator will be happier and more efficient.
    NewImprovedRon and Jack McCarthy like this.
  4. Mar 23, 2021 at 5:24 AM
    Larry6464
    Larry
    2002 Toyota tundra
    Ok thanks good to know. Also I will as add some more then......lol
    Tundra2 likes this.
  5. Mar 23, 2021 at 4:28 PM
    Hand Protectors
    Do your own math. Check the Fuse Rating and then look at the draw of your new lights and subtract the difference of the old lights.
    There are watts/volts/amps calculators on the internet for conversions.
  6. Mar 25, 2021 at 6:25 AM
    Larry6464
    Larry
    2002 Toyota tundra
    Hey I got another question for you. I know there has been alot of discussion on hood scoops. I know the fake ones dont have a purpose. But I like the looks. So two questions(1) will there be much air drag and (2) when water gets in through the front screen do u think in time will it mess up the paint or cause damage to the hood. Thanks in advance for ur response.
  7. Mar 25, 2021 at 6:45 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    If you're going faux scoop, just get one that sticks to the hood that doesn't have an opening. No cutting, no real opening for water to get in. Yes it will likely mess up your paint over time. Yes it will look a little silly to others, especially if it's not functional. Probably won't create much drag since there's no air inlet. But you do you and enjoy your truck the way you want to.
    jimf909 and des2mtn like this.
  8. Mar 25, 2021 at 12:29 PM
    Larry6464
    Larry
    2002 Toyota tundra
    Well the one I got has an opening with screen in front.
  9. Mar 25, 2021 at 12:56 PM
    shifty` One great big festering neon distraction
    Sounds awesome.
  10. Mar 25, 2021 at 2:15 PM
    Hand Protectors
    I’d be concerned like Karen that my Starter would get wet and all jacked up with the Scoops.
  11. Mar 25, 2021 at 2:48 PM
    You bring up a good point - plural. Everyone knows 2 scoops are better than 1.
  12. Mar 25, 2021 at 3:21 PM
    Hand Protectors
