Electric fans question
Discussion in 'General Tundra Discussion' started by Geo31106, Mar 22, 2017.
  1. Mar 22, 2017 at 1:21 AM
    Geo31106
    Geo31106 [OP] New Member
    2014 White Tundra SR5 Crew Cab
    Hello, I am new to the Forum, maybe they have answered this question already but couldn't find an answer.
    I am putting an Electric fan (Puller) with a home made shroud on my 2014 Tundra, can I also put a pusher fan with a On/Off manual switch in front of the condenser to help out on hot days (115-120 degrees) Arizona weather. Or doing it will make the puller fan not work properly??
  2. Mar 22, 2017 at 3:06 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Seems unnecessary, you don't want too much cooling you'll get check engine light p0128 most likely. if you really want to add a fan add a pusher to the front
    Law323 and 040Tundra like this.
  3. Mar 22, 2017 at 6:29 AM
    New member???...no pics of your ride???:worthless::smack:
    Bear likes this.
  4. Mar 22, 2017 at 9:18 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    It won't work. Both fans will work at different rates and will just cause excess turbulence that will reduce efficiency. If you look up the specs on quality fans, like SPAL for example, they usually flow higher volume in the pull method than the push method.
    Secondly, why do you even need this? If your truck is getting that hot, you probably have bigger issues..
  5. May 23, 2017 at 12:59 AM
    Geo31106
    aramirez73 here are some Pic's20170523_001137.jpg 20170520_142404.jpg 20170519_232826.jpg
  6. May 23, 2017 at 6:16 AM
    15whtrd
    15whtrd Mr. Blonde
    Nice looking truck!
  7. May 23, 2017 at 6:20 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Liking your truck brother!!
    Geo31106[QUOTED][OP] likes this.
  8. May 23, 2017 at 9:01 AM
    :thumbsup:
  9. May 23, 2017 at 11:38 AM
    Geo31106
    Thanks guys!!
  10. May 23, 2017 at 2:53 PM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    Great looking truck!
    Geo31106[OP] likes this.
  11. May 23, 2017 at 10:20 PM
    Geo31106
