Eibach stage 1 lift gen 2
Discussion in 'Suspension' started by Fcampa89, Feb 6, 2023.
  1. Feb 21, 2023 at 11:43 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Skip the diff drop. Not necessary.
    RobertD and MEWaters[QUOTED] like this.
  2. Feb 21, 2023 at 11:44 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Appreciate it. So realistically won’t hurt anything
  3. Feb 21, 2023 at 11:46 AM
    memario1214
    Colton
    Missoula, MT
    Correct. Except in fringe cases 2nd Gen Tundras don't need diff drops.
    MEWaters[QUOTED] likes this.
  4. Feb 21, 2023 at 12:42 PM
    Kung
    KG, VA
    I asked the same question and I was told they weren't needed.
  5. Feb 21, 2023 at 12:47 PM
    JRS
    JRS New Member
    2012 DCLB
    The CV can probably take it but your boot will likely throw grease (mine did and it seems like plenty of others after this amount of lift). I just ordered CVJ silicone boots, ORS outer boots, and the ECGS needle bearing replacement. Not saying you *need* to do it, but not saying it wouldn't be worthwhile when you've got those halfshafts out already depending on how good your boots look...
  6. Feb 21, 2023 at 12:52 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I left my front stage 2 at the setting out of the box and it measures the same as my neighbor’s TRD Pro. I figured that was good enough to not need it.
