EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Nov 10, 2022 at 5:54 AM
    #121
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    This x 2
  2. Nov 10, 2022 at 3:18 PM
    #122
    Firemedic1428
    Firemedic1428 New Member
    2022 Blueprint Platinum CM
    I am definitely interested for my 22 Platinum
  3. Nov 10, 2022 at 8:08 PM
    #123
    Front_Range_Pro
    Front_Range_Pro [OP] EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    …and now for the beauty roll! :cool:
    Production will start soon! We still want to finish out some more capability testing to make sure these perform as promised. We are also going to make sure an install video is good to go before the official release.
    For those who initially indicated interest and are on the list, keep an eye on your DMs. The first batch of units will be offered to you as a special thank you for your support and great input! We will also keep your name on our list so you can receive a special one-time code in the future which will be good for a discount and first-purchase opportunity on the passenger side unit when it comes available.
    Here are some built-in product highlights:
    • Overcharge protection
    • Over-temperature protection
    • LED indicator light
      • Blue/Green flash: power up
      • Blue: device detected and charging
      • Green: Device fully charged
      • Green Flash: non-supported item against the charger
    • Included:
      • PCBA 3-coil charging module
      • Durable high-temp housing made of ASA plastic
        • Anti-vibration internal circuit board mounts
        • Coil-protection film
        • 3D printed
      • USB-C fast charge cable
    • Designed, printed, and fabricated in the USA
    • US Veteran-owned company
    • Each unit assembled and QC tested prior to shipping to customer
    On the home stretch, guys! So very close now. :thumbsup:
    Russ_S, warriorlabs, dekeman and 11 others like this.
  4. Nov 11, 2022 at 6:26 AM
    #124
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    This is awesome - can’t wait to get it in my truck
  5. Nov 11, 2022 at 6:31 AM
    #125
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    Had a check engine light show up last night (620ish miles :()so I took it into the dealership today. Check engine light was of this morning but took it anyway and while I was there I asked about the charger just to see what they would say.
    Told me there was no way to adjust it and the coil is molded into the plastic. Working as designed. I could tell it wasn't the first time he had been asked that question.
    Looking forward to the fix here being available!
    ryanwgregg likes this.
  6. Nov 11, 2022 at 8:45 AM
    #126
    Breathing Borla
    AZ
    I don't understand the picture, is the face see through with holes? and is the cord on the front?
    what happens when you spill something on it?
  7. Nov 11, 2022 at 8:52 AM
    #127
    Breathing Borla
    AZ
    ok I see then the factory cover over that?
  8. Nov 11, 2022 at 9:04 AM
    #128
    Front_Range_Pro
    Vail, Colorado
    Yes. This will only work on trucks that came with the factory qi charger/plate for now. You will remove the factory qi charger from the back and replace it with this.
    All will be covered in the install video. :thumbsup:
  9. Nov 11, 2022 at 9:53 AM
    #129
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Interested 22 limited. Very interested in the dual charger setup
  10. Nov 11, 2022 at 1:10 PM
    #130
    jxb040
    jxb040 New Member
    Jeremy
    2022 Black Tundra
    Interested in the charger working!
  11. Nov 11, 2022 at 1:33 PM
    #131
    cokish
    cokish New Member
    Grigory
    Interested
  12. Nov 11, 2022 at 6:56 PM
    #132
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    So, is there a way to make this work in trucks that didn't originally come with a wireless charger?
  13. Nov 13, 2022 at 6:25 PM
    #133
    NJshadow93
    NJshadow93 New Member
    2022 Lunar Rock SR5 TRD Off Road
    Add me please. Thanks!
  14. Nov 13, 2022 at 8:16 PM
    #134
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    I already signed up as interested, but I'm curious if there's a way for me to unplug the LED light portion. I would prefer not to have it if possible.
  15. Nov 14, 2022 at 1:16 PM
    #135
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Sorry if this has already been asked, but will the centre screen still indicate Qi charging as it does with the factory charger? If not, will it show any faults or just always be greyed-out as if it's not charging?
  16. Nov 14, 2022 at 1:35 PM
    #136
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Interested!
  17. Nov 14, 2022 at 1:42 PM
    #137
    38Thumper
    38Thumper New Member
    Yes, I am interested!
  18. Nov 14, 2022 at 2:59 PM
    #138
    NCA100
    NCA100 New Member
    I’m very interested in a unit for vehicles without the factory option.
  19. Nov 14, 2022 at 5:53 PM
    #139
    Front_Range_Pro
    Vail, Colorado
    not sure if I understand what you mean.
    if you’re referring to the charge indicator in Apple CarPlay, that’s phone mirroring software. If the phone is charging, it will show on the CarPlay screen.
    The OEM qi charger has an LED indicator light next to the phone in the console piece.
  20. Nov 14, 2022 at 7:09 PM
    #140
    Front_Range_Pro
    Vail, Colorado
    List updated....
  21. Nov 14, 2022 at 7:37 PM
    #141
    myerswoodshop
    myerswoodshop New Member
    2022 Toyota Tundra Platinum
    Please add me to the list. I’m very interested.
    Front_Range_Pro[OP] likes this.
  22. Nov 14, 2022 at 8:29 PM
    #142
    M11s n B&T’s
    M11s n B&T’s New Member
    2022 Tundra TRD Pro
    I’d take one when available
  23. Nov 15, 2022 at 6:47 PM
    #143
    Green1794
    Green1794 New Member
    Austin
    2022 Green 1794
    I'm not sure if these have been officially released but I am absolutely interested. Dual iPhone charging capacity in my '22 1794 would be a huge upgrade. I would even settle for single phone charging that actually worked...
  24. Nov 15, 2022 at 7:02 PM
    #144
    MaKNEEgrowz77
    MaKNEEgrowz77 New Member
    Pat
    Plz add to list, interested in single or dual. Whatever may be available.
  25. Nov 16, 2022 at 1:07 AM
    #145
    Demar002
    Demar002 New Member
    2022 Toyota Tundra
    Interested.
  26. Nov 17, 2022 at 1:01 PM
    #146
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    That looks and sounds awesome! I am now interested.
  27. Nov 17, 2022 at 3:40 PM
    #147
    Littleschipper
    Littleschipper New Member
    SCPA
    2023 Supersonic Red 1794 Hybrid
    Count me in! Between my wife and I we both have different size phones and cases. A charger that works for both would be worth it!
  28. Nov 17, 2022 at 6:11 PM
    #148
    Sully77
    Sully77 New Member
    2015 Tundra TRD
    very interested
  29. Nov 17, 2022 at 10:24 PM
    #149
    Vader070
    Vader070 New Member
    2022 Windchill Pearl Tundra Platinum
    Interested!
  30. Nov 18, 2022 at 3:02 PM
    #150
    Front_Range_Pro
    Vail, Colorado
    Took it to work to try on as many different phone models as possible.
    Very pleased to report that it worked perfectly on every qi-enabled phone we could find including Apple and Android phones. We even got a set of AirPods to charge on it. :cool:
    https://youtube.com/shorts/Odh_Hw5K3j4?feature=share
    TheSS712, warriorlabs, murtro and 2 others like this.
