EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Oct 29, 2022 at 3:49 PM
    Russ_S
    Russ_S New Member
    Central New York
    2023 Tundra 1794 TRD Off Road
    Interested. Android Pixel user.
  2. Oct 29, 2022 at 3:56 PM
    splashflash
    splashflash New Member
    Art
    Timnath, CO
    2022 SS Red SR5 Sport Premium
    Interested on android and upgrade from not having the qi
  3. Oct 29, 2022 at 4:07 PM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    Interested. Pixel 6.
  4. Oct 29, 2022 at 7:44 PM
    rohmbd
    rohmbd New Member
    Yes please.... Android
  5. Oct 29, 2022 at 8:30 PM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    I don't have the factory wireless charger (base sr5), but if this new kit just requires us to buy the factory insert for the dash cubby and modify it, then I'm in 100%.
    TheGreenGoblin likes this.
  6. Oct 29, 2022 at 10:13 PM
    mullett757
    mullett757 New Member
    Joe
    2022 Lunar Rock SR5 Premium TRD Off-Road
    Front window Tint
    Interested!
  7. Oct 30, 2022 at 6:50 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Count me IN.
    Interestingly, had the exact same non-charge issue in a '22 Lexus LX 600 I drove last week. 10 seconds of charge then quit. Remove case, works fine.
  8. Oct 30, 2022 at 9:13 AM
    Front_Range_Pro
    Front_Range_Pro [OP] EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    :cool:
    It’s probably because Toyota uses the same qi charge module across their entire line. The one in the Tundra is found in Prius and Camry, for instance.
    The charging surface area is extremely small. Especially as it relates to modern “oversized” smart phones.
    First functional prototypes are being printed.
    :cool:
    KClav likes this.
  9. Oct 30, 2022 at 10:36 AM
    G19OD
    G19OD Mall Crawler
    Pacific Northwest
    Interested iPhone user. 2022 Pro and having the same connectivity issues.
  10. Oct 30, 2022 at 10:58 AM
    Spiny87
    Spiny87 New Member
  11. Oct 30, 2022 at 11:45 AM
    Mcdog727
    Mcdog727 New Member
    Steven
    2022 Tundra Limited
    I’m interested. Thanks
  12. Oct 30, 2022 at 11:52 AM
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    Interested!
    Samsung Galaxy 22+ user!!
  13. Oct 30, 2022 at 12:22 PM
    Nguyener13
    Nguyener13 New Member
    24 Lunar Rock Limited OR
    I'm interested. Samsung S20+ for now but once the iPhone 15 rolls out next year, I'll be jumping ship back to Apple.
  14. Oct 30, 2022 at 1:13 PM
    Max713
    Max713 New Member
    Put me on the list!
  15. Oct 30, 2022 at 6:32 PM
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
  16. Oct 30, 2022 at 8:48 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Interested for iPhone
  17. Oct 31, 2022 at 2:19 AM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Interested. iPhone 14 pro max
  18. Oct 31, 2022 at 4:37 AM
    bluefoot
    bluefoot New Member
    2022 Toyota Tundra 1794
    I'm interested, have an iPhone 14 pro and would love to see a genuine MagSafe with fast charging
  19. Oct 31, 2022 at 3:30 PM
    #49
    paladinkc
    paladinkc New Member
    KCMO
    2022 Black Platinum
    Definitely interested ...anything would be better that the weak charger we have now!
  20. Oct 31, 2022 at 3:53 PM
    #50
    Whitetail Assassin
    Whitetail Assassin New Member
    Interested! iPhone 13 Pro
  21. Oct 31, 2022 at 6:31 PM
    #51
    Kebmo25
    Kebmo25 New Member
    Please add me to the list of interested buyers. 22 Platinum with qi charger and iPhone 14 pro max. Thank you!
  22. Nov 1, 2022 at 1:34 PM
    #52
    Front_Range_Pro
    Vail, Colorado
    Gonna start doing some tests on charging speeds and maintaining the blue indicator light in the panel. :cool:
    pnw.tundra and KClav like this.
  23. Nov 1, 2022 at 10:55 PM
    #53
    Front_Range_Pro
    Vail, Colorado
    Initial tests are good.
    Using an actual MagSage was proving to be extremely difficult as the tolerances for distance between the charger and the phone are extremely narrow. This means that the thickness of the plastic console plus a standard MagSafe case were causing issues.
    That said, we think we found a solution and are planning to run some more tests. Some results from our first round of tests:
    • Much higher stability of connection
      • When placed on the charging surface, there are higher tolerances for phone placement. Which means you won’t have to fish around for a single exact spot to get a charge. You also be able to use thicker cases.
    • Charging speed increase of approximately 20% from our ver 1 tester
      • Just some generic tests but seeing as how the OEM charger put out hardly anything, this was a dramatic increase over OEM
    • Clean install
      • The exterior console surface will remain OEM.
      • No cutting
      • No drilling
      • Completely reversible
    • Multicolor LED charger indicator light in place of OEM light location
      • Blue, red, and flashing yellow to help indicate charging issues should any arise
      • Still has same OEM appearance
    • Android/other phone functionality (possibly)
      • For non-iPhone users, you won’t have to wait for us to find a separate solution for you
      • For use with any qi-capable phone
    NOTE: Not all phones have been tested for chargability. Charge times may vary based on the end-user’s phone model, power consumption patterns, case, etc. Initial tests thus far have been in a controlled environment and outside of vehicle. Tests have been done using Apple iPhone Mini, Pro, and Pro Max model phones.
    Testing continues and we are super excited to get this out to you guys ASAP but want to make sure we deliver on your expectations.
    Thanks for being patient
    https://www.instagram.com/reel/CkclH07Dje5/?igshid=YmMyMTA2M2Y=
  24. Nov 1, 2022 at 11:49 PM
    #54
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    This looks awesome. Count me in. Platinum iPhone 14 pro max.
    Assuming all the wiring will be plug and play?
  25. Nov 2, 2022 at 7:30 AM
    #55
    Balaraform
    Balaraform New Member
    Count me in platinum 14max pro
    ryanwgregg likes this.
  26. Nov 2, 2022 at 7:39 AM
    #56
    Front_Range_Pro
    Vail, Colorado
    cable will be hardwired into the charging unit. You would just be routing the cable through the center console and plug it into the USB-C port inside the storage area.
    The charging unit itself is secured to the back of the panel with a strong 3M-type double sided tape.
    Everything is self-contained. Instructions and an install video are planned for mounting and console disassembly.
    murtro and bballjames[QUOTED] like this.
  27. Nov 2, 2022 at 8:23 AM
    #57
    Front_Range_Pro
    Vail, Colorado
    The connector plugs directly to the back of the OEM qi charger. Our initial test of the OEM qi charger on an iPhone 12 Pro Max in airplane mode netted just 3% in 30 minutes and also cycled through connected/disconnected repeatedly. As of this post, we haven't been able to locate a female connector version of it to hardwire to our charger. All of our tests have been out of the vehicle on a similarly powered USB-C port. We wanted to maintain a plug and play product so until we can identify a connector solution that maintains the plug and play while keeping the charging rates at expected levels, the USB-C connection was the route we opted for. :thumbsup:
  28. Nov 2, 2022 at 8:25 AM
    #58
    Breathing Borla
    AZ
    that and knowing toyota, they likely have like .0025 amps going through the OEM charging wires, lol.
    as long as there are 0 wires visible and the face looks OEM, and install is very well laid out, I think you'll have a winner, you should be able to draw some decent power through the USB-C
    but it would be awesome to just unplug a wire harness to the OEM one and plug in the new one
    the OEM one was a train wreck on my test drive, it would not stay connected even if I held it there
  29. Nov 2, 2022 at 11:33 AM
    #59
    22TRDPROSOLAROCTANE
    22TRDPROSOLAROCTANE New Member
    22 PRO, iphone, interested
  30. Nov 2, 2022 at 1:12 PM
    #60
    osscie3
    osscie3 New Member
    Interested as well! 2022 Capstone
