EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Mar 18, 2023 at 8:48 PM
    #361
    ArticTundra
    ArticTundra New Member
    Cold
    I’ll take a dual as well once they got the market!
  2. Mar 19, 2023 at 7:46 AM
    #362
    HeavyB
    HeavyB New Member
    Joe
    I am willing to be a beta tester
  3. Mar 19, 2023 at 10:02 AM
    #363
    Stimleck
    Stimleck New Member
    im in for a single or a dual but only if it uses factory wiring harness plug
  4. Mar 19, 2023 at 8:11 PM
    #364
    Molly815
    Molly815 New Member
    Marty
    2023 Solar Octane Tundra TRD PRO
    Bed Cover
    I would like to know when these dual chargers are ready to hit the market. I am certainly in the market for something like this. The OEM unit sucks, will not charge with the Otterbox rubber of plastic cover
  5. Mar 21, 2023 at 9:52 AM
    #365
    Front_Range_Pro
    Front_Range_Pro [OP] EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    I post updates on here regularly. I also post updates on instagram. The dual Charger is still in testing and development phase with no timeline on its release yet. There are still some challenges to overcome first.
  6. Mar 24, 2023 at 5:16 PM
    #366
    Front_Range_Pro
    Vail, Colorado
    On sale May 1st: EEF Charger V2.
    Notable changes:
    • Updated chipset
    • Foreign Object Detection (FOD) improvements
    • Functionality increases
    • LED status indicator Light improvements
    ◦ Power on: Blue
    ◦ Charging: Red
    ◦ FOD activation: alternating Blue/Red
    ChuckL, kstateskier and SecrITSociety like this.
  7. Mar 25, 2023 at 4:08 PM
    #367
    HeavyB
    HeavyB New Member
    Joe
    Does it plug into the factory plug and any update on the double, that's what I really want
  8. Mar 31, 2023 at 8:32 AM
    #368
    Littleschipper
    Littleschipper New Member
    SCPA
    2023 Supersonic Red 1794 Hybrid
    Please count me in for a dual charger that connects to the factory cable or another power source other than the usb-c port in the console when it becomes available!
  9. Mar 31, 2023 at 8:33 AM
    #369
    Breathing Borla
    AZ
    I don't think any of these connect to the factory connection, you have to run to the USB port
  10. Apr 4, 2023 at 9:36 AM
    #370
    Front_Range_Pro
    Vail, Colorado
    Or do they? o_O
    You never know what the evil geniuses at EEF have cooking in the forges of badassery. :cool:
    Henry1jg likes this.
  11. Apr 4, 2023 at 10:03 AM
    #371
    HeavyB
    HeavyB New Member
    Joe
    I'm in!!!
  12. Apr 4, 2023 at 11:38 AM
    #372
    Breathing Borla
    AZ
    can I return mine then for one that just connects? lol
  13. Apr 4, 2023 at 8:30 PM
    #373
    CwickStylz
    CwickStylz New Member
    Andrew
    South Haven, MI
    2022 White Tundra Limited
    Please add me to your list as well.
    Gotta say, EXTREMELY psyched that somebody has already got a product just about ready to launch to fix this beyond silly issue by Toyota. Drives me absolutely crazy with the constant charging on / off, over & over & over.
    Definitely let me know when the product is ready to launch & thank you!
  14. Apr 5, 2023 at 1:24 AM
    #374
    Front_Range_Pro
    Vail, Colorado
    The single charger is already out at https://www.europeanenterprisesfirm.com/
    :thumbsup:
  15. Apr 5, 2023 at 6:20 PM
    #375
    CwickStylz
    Andrew
    South Haven, MI
    That's AWESOME!
    As for the dual version that's in the works, I've seen members asking if it'll work with the factory connector, but don't believe I saw an answer (but didn't go through 13x pages of posts either)?
    Also, I believe the stock Qi pad operates @ 2W (RIDICULOUSLY WEAK!), do you have the details on wattage for the current single solution & projected wattage for the dual solution?
  16. Apr 5, 2023 at 8:42 PM
    #376
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    +1, the dual charger, factory plug sounds like a winner.
  17. Apr 9, 2023 at 10:46 AM
    #377
    splashflash
    splashflash New Member
    Art
    Timnath, CO
    2022 SS Red SR5 Sport Premium
    Installed my Qi charger, but the light stays red regardless of there being a phone on it or not. Red when truck is on, red when a phone is 100% and on the charger, and red when a phone is charging on to (it does charge); just unsure if there's anything I should double-check?
  18. Apr 16, 2023 at 10:31 PM
    ptkursa
    ptkursa New Member
    2023 Solar Octane Tundra TRD Pro
    Did this work? I have same phone and same issue. Looking for solution
  19. Apr 17, 2023 at 3:10 AM
    #379
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Works better than the OEM one for sure, it doesn't charge as fast or as much as I'd like but the phone is still very picky and once in a while won't be charging.
    On a 1hr drive, it charges my Pixel 7 Pro about 2-3% only... So don't count on this to charge your phone, it's good to keep it topped up though if your phone is already charged up.
    Is it my phone the issue or the charger, not sure, but I have a feeling the USB connection under the armrest isn't pumping out enough Amps to the charger and in return wirelessly to my phone... Again, this is speculations on my part.
  20. Apr 18, 2023 at 6:40 AM
    #380
    Front_Range_Pro
    Vail, Colorado
    With regards to the Google Pixel 7:
    As per Google's product specification sheet, the Pixel 7 supports charging up to 20W but only with Google's proprietary chargers. If you are not using a Google charger (which the EEF chargers are not), the max charging power you will get is
    12W which lead to slower speeds.
    Additional factors may be at play to include case thickness, background applications/GPS tracking, and base operating power requirements which may further reduce speeds.
  21. Apr 18, 2023 at 6:49 AM
    #381
    Breathing Borla
    AZ
    whats the amp draw of your charger?
  22. Apr 18, 2023 at 11:37 AM
    #382
    Tundra-guy
    Tundra-guy New Member
    I installed my replacement single version and it work very well on my iPhone 11. No more charge disconnecting while driving. I ran a separate USB dual port from the passenger fuse box and hid all the wiring under the passenger side. Still looks OEM and I didn’t use any of my factory USB ports. I didn’t want to see any wires or tie up a USB. Thanks to EEF for making a product that works.
  23. Apr 26, 2023 at 10:59 AM
    #383
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    Is there an estimated timeline on the dual option?
    cruiserhead likes this.
  24. Apr 26, 2023 at 11:06 AM
    #384
    Breathing Borla
    AZ
    can someone point me to the final install video instructions ?
  25. Apr 26, 2023 at 12:15 PM
    #385
    cruiserhead
    cruiserhead New Member
    I’m waiting as well on the dual option. I have the single version but don’t want to tear things apart twice…would rather just install once. Hopefully it’s coming soon!
  26. Apr 26, 2023 at 12:22 PM
    #386
    Breathing Borla
    AZ
    Im kinda second guessing the entire tear apart the dash deal
    I may just sell mine.
    I dont see there was ever a final install video done, just the prototype, and your truck may or may not be different type deal in the first post that says its just a demo and not full instructions.
  27. Apr 26, 2023 at 12:56 PM
    #387
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    I used the video link from the prototype here and it was spot on. This video is from a TRD Pro and I have a Limited, but worked just fine. I did wire mine to a fuse tap under the glove box so I didn’t affect the usability of the console USB. Here’s the link:
    https://youtu.be/Ja_7LxEY_os
    Only tough part is the damn shift knob.
  28. Apr 26, 2023 at 2:20 PM
    #388
    Front_Range_Pro
    Vail, Colorado
    Apologies guys. I had to have a facial surgery early last month which pretty much sidelined me and affected my speaking ability let alone my on-screen appeal. Lol
    The dual Charger will not be mounted in the same fashion as the singles. The goal for the singles was to design them to fit into existing OEM pieces so that the factory appearance was maintained.
    This goal was carried over when we started developing the Dual Charger. However, because the existing panel pieces won’t allow for placement of a dual setup without EXTENSIVE modification to your OEM part, the decision was made to develop an “overlay” style panel that lays on top of your existing piece. There will be no requirement for disassembly except to disconnect the OEM charger or installed EEF unit.
    Because the EEF dual Charger will be openly displayed, there has been countless fit tests and adjustments to make it look like it as OEM as possible. This is in addition to testing and bridging two chargers together, torture testing, etc.
    Your patience has been noted at EEF and is tremendously appreciated. The dual Charger R&D has also yielded some other possibilities that you make find of use in the future as well. Can’t give too much away but I’m sure some people may rip out their hair plugs in disbelief. LoL
    :cool::rofl:
  29. Apr 26, 2023 at 2:42 PM
    #389
    cruiserhead
    Thanks! Hope you are feeling better. So if I want the dual charger, will that make the single charger I have basically throw away? Or will the dual charger work in hand or in sync with the single?
  30. Apr 26, 2023 at 3:37 PM
    #390
    Front_Range_Pro
    Vail, Colorado
    the single is still a good charger. But it must be disconnected to prevent interference with the dual Charger coils. Good news though: for those who have bought a single, EEF will offer discounts for the dual when it’s released.
    cruiserhead[QUOTED] likes this.
