Educate me on scanners...please
Discussion in 'Electrical' started by doggiecareman, Sep 23, 2021.
  1. Sep 23, 2021 at 6:33 AM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    So was wanting to know what product(s) are best for ongoing monitoring of tranny temps, oil pressure, engine temp, etc. Are the scanner modules designed to monitor real time or only snapshots when initiated? I am looking primarily for the ability to scan for a code when an alert comes on and monitor the tranny temps. I know there is much debate on the need/merit of tranny temp monitoring but since I have a '21 that was excluded from getting a factory transmission cooler I want to see what the real world effects are on not having one.
  2. Sep 23, 2021 at 6:42 AM
    LML 3500HD
  3. Sep 23, 2021 at 6:50 AM
    You can use the VeePeak OBD Bluetooth adapter and use the OBD fusion app. Both would be ~$40.00
  4. Sep 23, 2021 at 6:50 AM
    doggiecareman
    Eric
    North Central CT
  5. Sep 23, 2021 at 6:57 AM
    LML 3500HD
    Select between the two options and scroll down. For me, I would do the Data Monster (this is what would be equal to the CTS3 I have). I have a different "need" than most on here and purchased the Edge for a couple specific reasons.
    There are apps like what @Tundra234 suggested that might fit your needs at a way less cost to you and all you need.
  6. Sep 23, 2021 at 7:02 AM
    doggiecareman
    Eric
    North Central CT
    When I go to Amazon the choices for VeePeek OBD2 the choices run from 12.00 to 40.00. I see the Android only on one of them. Do you know offhand the primary differences?
  7. Sep 23, 2021 at 7:08 AM
    The one for 32.99 is the one that I have. I don't know what's different with the others.
  8. Sep 23, 2021 at 8:48 AM
    737fixer
    737fixer New Member
    To answer your question the monitors run realtime. Unless your a heavy tow person who wants a permanent gauge I can't see any reason not to use the OBD Fusion app. A $10 app or a $100-$400 dollar gauge is still reading the exact same sensors in the transmission. I also bought the above Veepeak from simply watching YouTube reviews. This guy has a bunch of educational videos along with this review video - The Ultimate OBD Scanner Buyers Guide & Speed Test (2019): OBD4Everyone E20 - YouTube The Fusion app with some simple messing around lets you set up the gauges literally a million ways. You can just have two gauges on your entire screen showing pan temp and torque convertor temp or you can add a MPH gauge, gear position gauge, several oil temps along with coolant, the choices are endless. Plus you can just turn off your phone and its gone. Greatest use so for for me was when doing transmission fluid drain & fill I can have the exact temp in front of my face under the truck for installing the fluid level plug.
    kittyhawk and doggiecareman[OP] like this.
