Best Gen-ECGS bushing tool
Discussion in '1st Gen Tundras (2000-2006)' started by FrenchToasty, Jan 4, 2020.
  1. Oct 13, 2021 at 2:30 PM
    #151
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Also for anyone buying anything from ECGS I used TW as a code to get free shipping.
    FrenchToasty[OP] likes this.
  2. Oct 13, 2021 at 2:31 PM
    #152
    FrenchToasty
    FrenchToasty [OP] The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Yeah let me know, karma wanted to make his own, but we talked it thru and I just sent him to tool.
    Dave8699[QUOTED] likes this.
  3. Oct 27, 2021 at 3:37 PM
    #153
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    @FrenchToasty how the tool looking? I started taking apart all the front end because I'm replacing everything except the cv axles which I was going to replace the leaking inner boot to CVJ red boot. But guess what the axle is shot. Super weird because it didn't make no noise and front end felt normal, but know I have to order CVJ full axle and see if I can return the boots. So not going to bother making the tool because going to have to wait for the axles.
  4. Oct 27, 2021 at 3:40 PM
    #154
    FrenchToasty
    Mo
    The SoAz
    None
    That sucks about your axle being kaput.
    Is it bad bad or just dry?
    Either way, the tool is still out, hopefully will be back soon. You can PM me your mailing info, and as soon as it comes back I can send it your way.
  5. Oct 27, 2021 at 3:49 PM
    #155
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    So the boot was ripped a little so it still has grease but not ball bearing :confused:. Also has play in and out obviously because it has no bearing.
  6. Oct 27, 2021 at 3:51 PM
    #156
    FrenchToasty
    Mo
    The SoAz
    None
    Pics? That’s super odd, I believe mine has the 5 ball design, not sure if other years used the tripod on these trucks or not.
  7. Oct 27, 2021 at 5:07 PM
    #157
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    You DO need that many measurements cause if you get it wrong in size and make it too big or too small it won’t fit inside the hole and outside of the bearing or it will scratch things up and cause a leak.
  8. Oct 27, 2021 at 5:14 PM
    #158
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    So yes I inspected it and it does have the bearing but there is alot of play in and out. Is that normal doesn't seem like it.
  9. Oct 27, 2021 at 5:18 PM
    #159
    FrenchToasty
    Mo
    The SoAz
    None
    Completely normal! That’s the point of them, when you’re suspension flexes, your cvs need to stretch but still apply power, that’s how it achieves this. Timmy the tool man does another video on rebooting cvs, the ones he shows are the tripod I mentioned earlier. But I’ve cleaned and regreased and rebooted those same CVs you have. I think the inner and outer both have play like that
  10. Oct 27, 2021 at 5:43 PM
    #160
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    So the inner has 2" of play and the outer has no play. So im I good to go how can I triple check them?
  11. Oct 27, 2021 at 5:55 PM
    #161
    FrenchToasty
    Mo
    The SoAz
    None
    I think your good. I’m not an axle or any kind of expert.
  12. Oct 27, 2021 at 5:57 PM
    #162
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    Ok back on track I guess I going to have to make the tool.
  13. Oct 28, 2021 at 6:05 AM
    #163
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    So I bit the bullet and ordered the tool. So once I'm done we will have 2 tools that can be sent out. I'm just don't have the patience to wait and not trying to scratch my diff. I want to a cnc shop because I was going to make the little bracket so I can sell it for cheap but they are super busy.
  14. Oct 31, 2021 at 9:36 AM
    #164
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    So I got the tool I do hqve to say they ship quickly.
    bmf4069 likes this.
  15. Oct 31, 2021 at 10:38 AM
    #165
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    All done let me know if someone needs the tool also. Just incase @FrenchToasty tool is not available.
  16. Nov 12, 2021 at 12:19 PM
    #166
    JustJake
    JustJake New Member
    2006 AC
    Has anyone had this fix a vibration issue? Or is is usually done preemptively?
  17. Nov 12, 2021 at 12:34 PM
    #167
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 tundra AC
    I believe if you have a vibration issue and it goes away when you put it in 4x4 then it's the needle bushing that's bad.
  18. Nov 12, 2021 at 12:53 PM
    #168
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yes, i has the vibration and this cured it
    Correct
  19. Nov 12, 2021 at 1:57 PM
    #169
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    You guys are the bomb! Lending out tools is a huge trust factor.
    Dave8699 and FrenchToasty[OP] like this.
  20. Nov 19, 2021 at 3:44 PM
    #170
    FrenchToasty
    Mo
    The SoAz
    None
    Tool and driver is back and ready for the next
  21. Nov 23, 2021 at 12:35 PM
    #171
    Casper421
    In the woods
    06 DC
    Once parts start coming in, you’ll get a pm.
  22. Dec 22, 2021 at 10:41 AM
    #172
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Got my bushing on order as well as new seals, both driver and passenger. Will likely pull the trigger on a passenger CV here in a few weeks.
    Speaking of, what’s the consensus on CV’s around here?
    Replace in pairs?
    How much lift until you need the R series from CVJ?
    Is the Toyota inner boot really that much better?
    I also hear talk of the NAPA axles?
    The ones from my donor are both OEM and I rebooted them during the swap (thanks @FrenchToasty) but the passenger has a nasty click with any steering input. If I went NAPA, I would likely keep my core so that I could go CVJ if I wanted to in the future but then at that price, you’re already creeping into CVJ $$ territory.
  23. Dec 22, 2021 at 6:36 PM
    #173
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I'm lifted 2" and I went with the more expensive CVJ axles but I did that because the boot is supposed to be better quality, not because I thought I had too much lift. I don't think you necessarily have to replace them in pairs. If both are OEM and only one is clicking then you could start with just one.
  24. Jan 29, 2022 at 6:22 PM
    #174
    daveeasa
    David
    Ok, so, for Tundra I should order bushing and seal and two axles? CVJ is the premium option? Or is there any upgrade for extra beef if potentially planning a front locker?
    Then the matching bushing and seal for my 2016 Tacoma too? And TW gets free ship?
    Anything I’m missing?
  25. Jan 29, 2022 at 6:33 PM
    #175
    FrenchToasty
    Mo
    The SoAz
    None
    I think cvj is the most upgrade/beefyness you can find.
    If your replacing both front CVs you’ll want seals for both sides and then the bushing
    daveeasa[QUOTED] likes this.
  26. Jan 29, 2022 at 6:52 PM
    #176
    daveeasa
    David
    Thanks, I think I get it.
    cvj:
    9550-tr x 2
    ECGS:
    T7.5-bushing w seal
    Asi-t8cs-d
    Asi-t8cs-p
  27. Jan 29, 2022 at 7:00 PM
    #177
    FrenchToasty
    Mo
    The SoAz
    None
    Yep, bmf posted in the other thread, but this is basically what you’d need besides your axles
  28. Feb 15, 2022 at 7:33 PM
    #178
    Mctwist77
    Mctwist77 New Member
    Peter
    FrenchToasty, is the tool available?
  29. Feb 15, 2022 at 7:38 PM
    #179
    FrenchToasty
    Mo
    The SoAz
    None
    Hey Peter, the tool is out right now in Ohio. Hopefully it should be back in a few weeks.
  30. Feb 15, 2022 at 7:43 PM
    #180
    daveeasa
    David
    FWIW, I bought the tools and both 3rd gen Tacoma and FGT adapter whatevers, all in a box right now, so if someone in north county SD wants to do theirs and help me figure out how to do mine, should be game on once the truck comes home.
    bmf4069 and FrenchToasty[OP] like this.
