Eccracer104’s not totally stock 16’ CM 4x4
Discussion in '2.5 Gen Builds (2014-2021)' started by eccracer104, Jan 24, 2021.
  1. Jun 12, 2022 at 10:18 PM
    #751
    eccracer104
    eccracer104 [OP] Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
  2. Jun 12, 2022 at 10:25 PM
    #752
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  3. Jun 12, 2022 at 10:30 PM
    #753
    eccracer104
    San Diego, CA
    Thanks! It was a damn good time!
  4. Jun 20, 2022 at 12:54 PM
    #754
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Damn, this build is sweet!! I gotta go through the whole thing now, I found it in my search. Since you did the spindle gussets, do you think they can they be done while they’re on the truck?
  5. Jun 20, 2022 at 4:37 PM
    #755
    eccracer104
    San Diego, CA
    Thank you!
    I suppose it could be done on the truck, but I’d take them off for piece of mind that you don’t overheat/melt any bushings or the cv axles.
  6. Jun 20, 2022 at 5:25 PM
    #756
    BlueRibbon4x4
    Geno
    Got it, thank you!
  7. Jun 22, 2022 at 3:38 PM
    #757
    eccracer104
    San Diego, CA
    Status update on the skid plates for anyone interested. After a fellow member advised me the issue I’m experiencing is due to receiving Land Cruiser skids instead of Tundra skids I reached out to Bud Built with my issue. They said my skids are correct and are sending out the correct hardware because unbeknownst to me I had previously received the incorrect hardware.
    Did this fix the problem: TBD :burp: :fingerscrossed:
    Drainbung, tundra_20 and SAGE63 like this.
  8. Jun 23, 2022 at 8:41 AM
    #758
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I went out to Sand Hollow a few summers ago in August and temps were also in the 105 - 110 range and it was miserable. Didn't do any trails in Sand Hollow (just chilled by the lake and got 3rd degree sunburn on the 2nd day of a two week trip), but did some off-roading in Hurricane/La Verkin, Cap Reef, Moab and Arches.
  9. Jun 23, 2022 at 8:44 AM
    #759
    DividedSky
    Jeff
    I use a Bad-Elf gps to bluetooth to an ipad running Gaia... Hasn't let me down yet!!
    eccracer104[OP] likes this.
  10. Jun 23, 2022 at 9:13 AM
    #760
    eccracer104
    San Diego, CA
    Oh man that sounds brutal. The sunburn that is. The heat we already know was rough haha.
    Sounds like it was a rad trip though!
    Drainbung and tundra_20 like this.
  11. Jul 22, 2022 at 4:20 PM
    #761
    eccracer104
    San Diego, CA
    My headlights were looooong overdue for a cleaning. Picked up the heavy duty Meguiars kit and went to work.
    Here they are pre-treatment
    Then the stages.
    1000 grit sanding:
    3000 grit sanding:
    Then polishing:
    And lastly, sealant:
    Before and after:
    And pose!
  12. Aug 22, 2022 at 3:23 PM
    #762
    eccracer104
    San Diego, CA
    Solid engine mounts arrived today! Now I need to find time and coordinate schedules with @tundra_20 to install them.
    79B7A617-0143-413B-92EE-C922F8058219.jpg 23EC1357-2BAE-4C70-9DF3-285ED5F39B99.jpg
    pvn.beluga, saybng, Drainbung and 5 others like this.
  13. Aug 22, 2022 at 3:30 PM
    #763
    SAGE63
    San Diego County
    Hope my reds show soon...double up on the install
  14. Aug 22, 2022 at 3:43 PM
    #764
    tundra_20
    tundra_20 New Member
    Lance
    Kyle, TX
    2020 Limited Double Cab
    I forgot to put my out of office reply on :rofl:
  15. Sep 15, 2022 at 11:41 AM
    #765
    eccracer104
    San Diego, CA
    Spare 37” mounted and balanced in time for San G
    pvn.beluga, Drainbung, Mater and 7 others like this.
  16. Sep 15, 2022 at 6:31 PM
    #766
    breynolds
    breynolds New Member
    Future Tundra owner
    Next time your headlights fade, sand out the fade to 800 grit and paint the lights with 2K clear coat off Amazon. Same clear coat they use to paint cars, they'll hold up WAYYY longer.
    Sunnier and eccracer104[OP] like this.
  17. Sep 15, 2022 at 8:28 PM
    #767
    eccracer104
    San Diego, CA
    Wow, all the way to 800?
    2K clear coat, check! :thumbsup:
    Thank you for the advice!
    tundra_20 likes this.
  18. Sep 15, 2022 at 8:30 PM
    #768
    breynolds
    Future Tundra owner
    Yup any more than 800 and I think the 2K clear won't stick as well. Did my 4runner headlights like this and they've looked the same for over a year now.
  19. Sep 15, 2022 at 8:31 PM
    #769
    eccracer104
    San Diego, CA
    Right on! By chance did you take any pics of them?
  20. Sep 15, 2022 at 8:37 PM
    #770
    breynolds
    Future Tundra owner
  21. Sep 21, 2022 at 3:20 PM
    #771
    eccracer104
    San Diego, CA
    Semi-temporary-permanent spare tire mount in place!
    CC72D6BF-E023-4043-8B24-E926792EAD5D.jpg 08F6DA6F-A8DD-44FB-AE88-6507D2F32A11.jpg
  22. Sep 21, 2022 at 3:35 PM
    #772
    SAGE63
    San Diego County
    Where is the 2nd Spare...
  23. Sep 21, 2022 at 3:46 PM
    #773
    eccracer104
    San Diego, CA
    I’m glad to have one full size, let alone two. Haha.
    tundra_20 and SAGE63[QUOTED] like this.
  24. Sep 21, 2022 at 4:30 PM
    #774
    Sunnier
    Sunny
    San Diego, CA
    Secured how?
  25. Sep 21, 2022 at 5:07 PM
    #775
    eccracer104
    San Diego, CA
    Two tie down straps.
    Been here for a couple days now, no movement. Idk if it’s desert running strong but should work for this trip.
    HAMi, tundra_20 and Sunnier[QUOTED] like this.
  26. Sep 21, 2022 at 5:11 PM
    #776
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Savage…:rofl:
    2 is 1 and 1 is none…
    2 the adventure continues, 1 will get you home..
  27. Oct 7, 2022 at 10:12 PM
    #777
    eccracer104
    San Diego, CA
    :itllbuffout:
    Before:
    Several hours later:
    Only an eternity to go :laughing:
    pvn.beluga, HAMi, Sunnier and 5 others like this.
  28. Oct 7, 2022 at 10:28 PM
    #778
    SAGE63
    San Diego County
    damn thats some work
  29. Oct 7, 2022 at 10:28 PM
    #779
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Careful on how far you chase those out, only so much paint you can remove before you’re in a world of hurt….
  30. Oct 7, 2022 at 10:32 PM
    #780
    eccracer104
    San Diego, CA
    Got that right.
    I’m using foam, no wool, so less a chance for burn through. I am using a heavy cut compound and a heavy cut pad, but letting the machine work with moderate but firm pressure. Trying to play it on the safe side while still doing enough.
    I’ve toyed with the idea of color sanding, but that’s above my pay grade and don’t want to test the waters on my truck haha.
    I might swap out the front driver fender with an un-dented one I picked up if I can get some of the marks off that. If so can do some experimentation on that, but honestly don’t think I have it in me haha.
