Eccracer104’s not totally stock 16’ CM 4x4
Discussion in '2.5 Gen Builds (2014-2021)' started by eccracer104, Jan 24, 2021.
  1. Feb 19, 2022 at 7:36 AM
    #631
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Sweet, thanks for providing those pics, Im convinced that with the new lift height our steering stops being ineffective and we gain more steering angle than OE. Out of curiosity how many turns from center to lock in each direction do you have?
    - jason
  2. Feb 19, 2022 at 8:33 AM
    #632
    eccracer104
    eccracer104 [OP] Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I want to say 2.5 rotations, but I’ll need to check.
    Drainbung likes this.
  3. Feb 19, 2022 at 8:52 AM
    #633
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Mike, I have 2 of those Arcan jacks. I highly recommend the Pro Eagle pad/extension mod. You'll want to talk to Chuck and get the center bolt too.
    Rc23, Drainbung, tundra_20 and 3 others like this.
  4. Feb 19, 2022 at 8:53 AM
    #634
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Nice Mike
  5. Feb 19, 2022 at 8:57 AM
    #635
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Very nice Mike, 37’s are the new 35’s. Lol
    What alignment shop were you recommended, East County Alignment?
    I have the issue of shop hours mirroring my work hours. My last two alignments have been expensive, paid for alignment plus a Lyft to and from work. I don’t work close to a shop I trust to align my truck so the Lyft rides get pricey.
    You can get the alignment pretty solid at home with patience, a tape measure and one of these.
    Johnson Level & Tool 1886-0000 Magnetic Digital Angle Locator w/ 2 Buttons, Orange, 1 Locator https://www.amazon.com/dp/B00H7HVGES?_encoding=UTF8
    I’ve only watched it being done but haven’t attempted it myself.
  6. Feb 19, 2022 at 9:30 AM
    #636
    Sunnier
    Sunny
    San Diego, CA
    Lmk if you want me to take it to Chris… we could swap trucks for a day…. ​
  7. Feb 19, 2022 at 10:04 AM
    #637
    eccracer104
    San Diego, CA
    Good to know! The jack is great but doesn’t lift the truck anymore unless it’s from under LCA or rear axle. I’ll definitely look into this.
    Thanks Francis!
    Haha totally.
    Yeah, was going to go there. I more of less understand the effect adjusting the uppers and following this thread for guidance.
    https://www.tundras.com/threads/how-to-do-an-alignment-at-home.136/
    I’ve also read @osidepunker advice on home alignment.
    Yup. Going to grab one of those or the like and cut some steel to match my wheel so it’s easy to replicate over and over.
    Thanks Sunny! I’ll keep you posted!
  8. Feb 19, 2022 at 2:10 PM
    #638
    SAGE63
    San Diego County
    Whats on the grinder er agenda today...
    Drainbung and eccracer104[OP] like this.
  9. Feb 19, 2022 at 4:17 PM
    #639
    eccracer104
    San Diego, CA
    At my nieces birthday. No truck stuff today.
    Drainbung and BiggHertz like this.
  10. Feb 19, 2022 at 4:28 PM
    #640
    SAGE63
    San Diego County
    cool enjoy. thinking otay mountain trail tomorrow
  11. Feb 20, 2022 at 9:18 PM
    #641
    eccracer104
    San Diego, CA
    Round 1 DIY alignment:
    Man oh man is there a learning curve. Got it significantly better than it was before, still going to need some more adjustment but much improved.
    pvn.beluga, Cruzer, Drainbung and 4 others like this.
  12. Feb 21, 2022 at 9:11 AM
    #642
    eccracer104
    San Diego, CA
    Partly note to self, partly note for others:
    Alignment notes for heimed uppers:
    Set LCA to max caster -
    Rear cams are all the way out - to push the rear of the lower arm out.
    Front cams are all the way in - to pull the front of the lower arm in.
    UCA heims are the opposite -
    Front heim was brought out some, but the rear heim closer to the cab was brought out further which aided in adding positive caster.
    Disclaimer - no idea if this is true for all - but it’s what worked for me.
    I still need more adjustment to add a little more caster and take away some of the camber but now I have a sense of what does what when adjusting.
    Edit: budbuilt engine skid needed to be notched to access the rear of the front cams. Pulling all the skids proved incredibly helpful as LCA cams are torqued to ~200lbs
    pvn.beluga, jc153, Drainbung and 2 others like this.
  13. Mar 1, 2022 at 7:00 PM
    #643
    eccracer104
    San Diego, CA
    Just got my power steering recall notice. Have any of y’all gotten that done yet?
    tundra_20 and Drainbung like this.
  14. Mar 1, 2022 at 7:02 PM
    #644
    eccracer104
    San Diego, CA
    Oh! And went to get my tires rebalanced since there’s mild shake at 55. Tech is saying I have a slightly bent wheel. So that’s sweet. Not bad enough to lose air thankfully. I’ve yet to take the wheel off and inspect it.
    pvn.beluga, tundra_20 and Drainbung like this.
  15. Mar 1, 2022 at 7:18 PM
    #645
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    I got it yesterday but the way I'm reading it is, you don't have to worry about it unless you had a steering gear repair since 8/5/21.
    SAGE63, Sunnier, tundra_20 and 2 others like this.
  16. Mar 1, 2022 at 7:19 PM
    #646
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Yah that’s the way I read it
  17. Mar 1, 2022 at 7:21 PM
    #647
    eccracer104
    San Diego, CA
    My current rack doesn’t have any issues that I’m aware of, just 87k on it and I’m thinking a fresh rack on Toyota’s dime isn’t a bad idea.
    As far as I know it’s never been touched.
    Drainbung[QUOTED] and tundra_20 like this.
  18. Mar 1, 2022 at 7:52 PM
    #648
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    From my quick read of the recall it sounds like you have to have the new steering gear and one of the indicators is that it's seeping/leaking PS fluid. I'll keep an eye out for leaks and go from there.
  19. Mar 1, 2022 at 8:28 PM
    #649
    eccracer104
    San Diego, CA
    Ahh good to know. I’ll poke around it. I haven’t read the letter yet, nor have I really looked for leaks.
  20. Mar 1, 2022 at 9:23 PM
    #650
    Sunnier
    Sunny
    San Diego, CA
    How I read it too. Looks like only a very limited number of production months, or repairs during a brief window would be affected.
  21. Mar 2, 2022 at 7:35 AM
    #651
    SAGE63
    San Diego County
    yeah received it for my 21... only applies if you had a repair after a certain date
  22. Mar 2, 2022 at 7:36 AM
    #652
    SAGE63
    San Diego County
    cannot like this...
  23. Mar 2, 2022 at 7:39 AM
    #653
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Make it the spare
  24. Mar 2, 2022 at 8:26 AM
    #654
    eccracer104
    San Diego, CA
    That’s the plan. @Porschetech29 is hanging on to a take off for me when he mounts his new tires. Once I get that I’ll swap the bent wheel to spare and mount that tire to it and swap the current tire to the good wheel.
  25. Mar 2, 2022 at 8:45 AM
    #655
    eccracer104
    San Diego, CA
    Next step is figuring out what the hell to do with a full size spare :rofl:
    I’m thinking about making a tire gate. Not sold on that yet, but at the moment it seems like the best solution.
  26. Mar 2, 2022 at 8:53 AM
    #656
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    had the same dilemma, ended up deciding to strap the spare into the bed when needed for trips using the SDHQ Tire Strap and SDHQ mount Kit (both on back order...who knew people actually use this stuff...lol) and store it in the garage when not in use...
    If you're looking for a bolt on component to replace tailgate, take a look at wilco.
  27. Mar 2, 2022 at 9:00 AM
    #657
    eccracer104
    San Diego, CA
    They make good straps! Haha.
    I could throw it in the bed, but with my RTT mounted so low I’d need to adjust my camp gear storage to fit everything. I try to keep the inside mostly open so my dog has room to be comfortable.
    I’ve seen the Wilco options, just too much money. If I DIY one it’ll be bolt on as well. I was trying to figure a way to make it swing open and drop down but that doesn’t seem feasible.
  28. Mar 2, 2022 at 9:00 AM
    #658
    Cruzer
    Cruz
    Sunnyvale, CA
    Welcome to our world! I got rid of the back seats and use a threaded rod to keep the tire in place. I know, not ideal for the dogs, which I put the tire in the bed when the dogs are in the truck.
    I bought the ADD spare tire carrier, which I’m going to somehow figure out a way to mount inside the cab so that the tire is vertical up along the back window. That way dogs and tire can both fit :D
  29. Mar 2, 2022 at 9:06 AM
    #659
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yup, everyone's situation will be different especially with loadouts and all. I too will be planning on installing an RTT as low as possible to keep CoG down. but hopefully won't be needing the spare anytime soon (just jinxed myself now). Ideally i'd like to keep it mounted towards the tailgate for weight distribution, but I figured loading the tire in first would be a butt load easier than a fully loaded 65 qt cooler, especially when trying to maneuver under a low mounted RTT.
    All about compromises.
  30. Mar 2, 2022 at 9:15 AM
    #660
    eccracer104
    San Diego, CA
    Hahaha I’m in for the crash course!
    It’s funny, I had always thought I’d just strap it in the bed because I wouldn’t get an RTT but my gal feels safer up high as opposed to a ground tent so here we are.
    I’d have so much room if I gut the back seat! And maybe I’ll explore that option more, build a platform or something. But there have been many times when the back seat has been needed for my nieces.
    Lol, quick knock on wood! Mine is about 2” above the bed rails. About as low as one can go. I’ve contemplated shifting the RTT back and slipping the tire between the tent and the cab at the front of the bed - but in the event I need it it’ll be a bitch to get out. Definitely the most cost effective solution though.
    Drainbung and BiggHertz[QUOTED] like this.
