Eccracer104’s not totally stock 16’ CM 4x4
Discussion in '2.5 Gen Builds (2014-2021)' started by eccracer104, Jan 24, 2021.
  1. Jun 4, 2021 at 10:14 PM
    #361
    TheBeast The Beach
    costco pumps do it for me all the time. Other gas stations no issues. Not sure whats up at costco. It will pump 2 or 3 gal then stop then i Have to fiddle around then again 3 gal..annoying
    eccracer104[OP] and Rica25 like this.
  2. Jun 4, 2021 at 10:32 PM
    #362
    SAGE63
    San Diego County
    yeah me too. have to hold the nozzle up as straight as possible
    TheBeast and Rica25 like this.
  3. Jun 10, 2021 at 7:50 PM
    #363
    eccracer104
    eccracer104 [OP] Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Great news! Got my tracking notification for my skids! Woohoo! Only 202 pounds :laugh:
  4. Jun 10, 2021 at 8:46 PM
    #364
    SAGE63
    San Diego County
    what skids did you get
  5. Jun 10, 2021 at 8:58 PM
    #365
    eccracer104
    San Diego, CA
    BudBuilt 3/16” steel
  6. Jun 10, 2021 at 9:07 PM
    #366
    Rica25
    Ricardo
    Tulare
    I was going to get those for the Fj but went with RCI. Not an easy decision
    joonbug, tundra_20 and Drainbung like this.
  7. Jun 15, 2021 at 9:19 PM
    #367
    eccracer104
    San Diego, CA
  8. Jun 16, 2021 at 7:58 PM
    #368
    eccracer104
    San Diego, CA
    Skids have arrived!
    Got them prepped, tomorrow after work I’ll lay down some paint :woot:
    Cruzer, ColoradoTJ, Drainbung and 5 others like this.
  9. Jun 16, 2021 at 8:10 PM
    #369
    tundra_20
    tundra_20 New Member
    Lance
    Kyle, TX
    2020 Limited Double Cab
    Looking good Mike! :thumbsup:
  10. Jun 16, 2021 at 8:49 PM
    #370
    MotoTundra
    MotoTundra The Ocho
    Don
    :headbang: I like it! Sick build btw!
  11. Jun 16, 2021 at 9:03 PM
    #371
    eccracer104
    San Diego, CA
    Thanks man!
    I retrofitted my Tacoma, was only a matter of time until I did it for the Tundra.
    Your write up was key! I’ve never messed with Permaseal before and in your write up you said something like separate the adhesive and I was like “wtf” and proceeded to try and pry apart like my Tacoma. Wrong. Eventually figured out what you meant and made my way all the way around the headlight with a small thin flat head and basically scraped the permaseal from the lens and it started to become easier. From there worked around the whole thing and once I felt it was separated enough started to pry and it began to give way. Took three or four bakes on the first light, then 2.5 bakes on the second (kinda got the hang of it).
    But that first light I was all “fuck this shit I’m over it” and by the end “I could probably do this again” :rofl:
    I have a “free” Mini H1 kit I’ll be throwing in. Once I sell the loaner headlights I picked up I should only be in it my time and a can or two of paint. #BudgetRetro
  12. Jun 17, 2021 at 12:13 PM
    #372
    eccracer104
    San Diego, CA
    Decided it would be wise to replace fluids prior to skids going on.
    Ordered Ravenol J1C1003 MTF-3 75w for the transfer case which will be here sometime next week.
    I’ll run by the auto parts store for Mobil 1 75w-90 synthetic (with LSD additive) for the diffs.
    With nearly 70k on the odo and unknown if the prior owner had it changed it’s a bit overdue as well. He claims to have done all required services as per the manual.
    ColoradoTJ, tundra_20 and Drainbung like this.
  13. Jun 17, 2021 at 9:07 PM
    #373
    eccracer104
    San Diego, CA
    Update:
    Got one side of the skids painted, and painted the headlights for the retrofit. Was shooting to work on assembly today but my soon to be sister in law got a flat, so went out and got that swapped out for her.
    Just got home and now I’m tired haha.
    Tomorrow should include painting the other side of the skids, and potentially some assembly of the headlights.
    My previous retro was all satin black everything with tinted amber reflectors. This time going with gloss black signal and headlight bowl, satin black shrouds, and leaving the corner reflectors amber. Hopefully they turn out well! (And hopefully the retro parts are in working order :laugh: )
  14. Jun 18, 2021 at 12:00 PM
    #374
    MotoTundra
    MotoTundra The Ocho
    Don
    Yeah it’s much different! I felt the same. Once you get the hang of it, it isn’t so bad. Can’t wait to see the final product! Once I finished that retro I wanted to do another one with different parts just to do it. Life has been a bit too busy though, haven’t gotten started on it yet.
  15. Jun 18, 2021 at 12:08 PM
    #375
    eccracer104
    San Diego, CA
    Thanks! Don’t get your hopes up too high haha. It’ll be a very basic retro. Just the blackout + Mini H1. Wish I had better lenses to glue on, but I’ll see what I can do with cleaning mine up.
    I helped retrofit my buddy’s 4th gen t4r and that was interesting as it was replacing a projector with a projector. Mounting holes didn’t line up which made for a unique challenge.
    One day I’d like to use better projectors like DS2. Mini H1 is super easy with the H4 alignment plate. Only time will tell if it’s aligned correctly or not. On early 2nd gen tacos it’s practically plug and play, but late 2nd gen tacos Toyota rotated the bulb meaning the alignment plate needed modification to work. We’ll see what happens on 3rd gen Tundra headlights.
    Still need to assemble, wire, set aim and rotation. Then scrape out the old permaseal, reseal, and put her together.
  16. Jun 19, 2021 at 8:37 AM
    #376
    MotoTundra
    MotoTundra The Ocho
    Don
    Roger that. The output will be anything but basic though!:thumbsup:
  17. Jun 19, 2021 at 6:41 PM
    #377
    eccracer104
    San Diego, CA
    Oh for sure! Night wheeling in the desert has been awful with the stock headlights. This will be a big help while I figure out where I’d like to add aux lighting.
  18. Jun 19, 2021 at 8:15 PM
    eccracer104
    San Diego, CA
    Aux lighting may have been handled courtesy of @pbcolt :fistbump:
    He’s hooking me up with an Nfab light mounting bar - funny enough I sold to him back when I was with AutoAnything haha.
    Just need to save up and find some lights to mount to it :woot:
    Rica25, tundra_20, Sunnier and 4 others like this.
  19. Jun 19, 2021 at 10:19 PM
    #379
    Sunnier
    Sunny
    San Diego, CA
    Seems those good deed discounts you did at Auto Anything are starting to pay dividends. :thumbsup:
    Rica25, Black Wolf, tundra_20 and 2 others like this.
  20. Jun 20, 2021 at 7:42 AM
    #380
    eccracer104
    San Diego, CA
    Who would have thought! :thumbsup::bananadance:
  21. Jun 20, 2021 at 3:51 PM
    #381
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Heading to Grand Junction tomorrow morning for rear leafs. Rear ADS shocks showed up on Friday from DSM, just in time. Still waiting on the front coils so I'll drive home with a wee bit of rake like a buckboard...pics to follow. Not trying to thread-jack.
  22. Jun 20, 2021 at 3:59 PM
    #382
    eccracer104
    San Diego, CA
    Sub’d for pics! :popcorn: :D
  23. Jun 20, 2021 at 9:01 PM
    #383
    Sunnier
    Sunny
    San Diego, CA
    Got your goods in hand. Ready to hand off. :spy:
  24. Jun 20, 2021 at 9:23 PM
    #384
    eccracer104
    San Diego, CA
    It’s too “crowded” here, meet you in the alley behind “the spot” :spy:
    :laugh::cookiemonster:
    Wooo! I’ll shoot you a message and we’ll figure it out :cheers:
  25. Jun 21, 2021 at 7:55 PM
    #385
    eccracer104
    San Diego, CA
    Got the headlights in and set rotation.
    Turns out on the 3rd gens the H4 bulbs are put in rotated so the alignment tab doesn’t work and needs to be ground down.
    Next I’ll need to clean the housings and seal them up then they can go in for real!
    Also got working on the skids.
    These things aren’t as straight forward as they were on the Tacoma :rofl:
    First note - the front skid does not go on first lol. Start with the engine skid.
    When I went for the trans skid the bolts provided don’t have a means to “lock” in place. They’re the button head bolts with a square flange, but they rotate in the slots soooo that’s neat.
    Ended up only bolting on the engine skid and the front skid. I got tired. Trans and transfer can go on at another date.
    Oh, and drained the front diff - to my surprise nice clean oil came out. So turns out the prior owner did do all the proper services. Filled it back up with new synthetic oil because no way I was using it after it mixed into my dirty oil pan.
    That’s all for today’s update, time for dinner and a beer :burp:
    des2mtn, jc153, tundra_20 and 2 others like this.
  26. Jun 21, 2021 at 8:10 PM
    #386
    eccracer104
    San Diego, CA
  27. Jun 22, 2021 at 6:04 PM
    #387
    eccracer104
    San Diego, CA
    Retrofit complete :woot:
    F20B6A55-9A30-468E-9A51-889D8F72D65E.jpg 47AFA2ED-DF3C-4A8D-AB27-F531A88337D8.jpg
  28. Jun 23, 2021 at 11:02 AM
    #388
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Got Rake? Reverse Brodozer! Hopefully DSM gets the front kit out soon...
    tundra_20, HAMi, SDtrueblue and 3 others like this.
  29. Jun 23, 2021 at 11:36 AM
    #389
    eccracer104
    San Diego, CA
    Damn Bob, save some rake for the rest of us :rofl:
    tundra_20, HAMi and Drainbung[QUOTED] like this.
  30. Jun 23, 2021 at 7:25 PM
    #390
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Scored a set of 5100s so I can get them installed with the new UCA's until DSM gets me the ADS's.
