EBC BRAKES/ Thoughts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by hi_rawb, Feb 10, 2022.
  1. Feb 11, 2022 at 1:14 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Your very welcome!
    I almost went with Sparks but wanted to get them fast so went semi local.
    Had to call around to find a dealership that had them in stock, the right OEM parts, at a reasonable price.
    These pads were not really reasonable, but for Factory quality I don't mind paying a bit more.
    I have had to many brake issues on vehicles over the years using cheap ass knock off junk from random auto parts stores and supposedly higher quality "performance" parts.
    Nowadays I avoid aftermarket for certain maintenance items like I mentioned previously.
    Just not worth the hassle and I like the peace of mind.
    The dealer did not give me anything last time, this was my first front brake replacement and they said they use these $70 pads.
    I told the parts guy I want exactly what comes on the truck from the Toyota Factory.
    He said oh ok, then you want this other one that is $120 a set.
    Not sure about the 18-21 models different part numbers, news to me.
    My truck is a 2014 and they looked up parts by my VIN.
  2. Feb 11, 2022 at 1:22 PM
    10k isn’t bad for what you do Dave. Desert pounding isn’t easy on brakes for sure. Glad you like the EBC’s. Even looks sweet on your truck.
    How you liking all that Blue stuff on all four corners?
  3. Feb 11, 2022 at 4:20 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Just over 55,000 mi on my stock front and rear pads and rotors.Ill be doing brakes in the spring.Be close to 60k on the stock pads and rotors
    Joe333x[QUOTED] likes this.
  4. Feb 11, 2022 at 4:27 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    44k on the clock and I’m ready to ditch the OEM stuff.
  5. Aug 26, 2022 at 9:25 AM
    16wtundra
    16wtundra New Member
    San Diego, CA
    16 CM 040
    Falcon suspension w/ +2 shackles, DAP
    Bout to change pads from oem to ebc yellows. Heard you need the shims that usually dont come with the brake kits. Has anybody have issues with noise cause of the missing shims or know how to get a replacement shims?
  6. Aug 26, 2022 at 9:52 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Front pads are the ones that get shorted. The box will likely come with four shims. You need eight. Just email EBC Brakes in USA from their website and they'll send the other four. Mention that your truck is a Tundra with 4 piston calipers.
    Checking my email, this is what I used: sales@ebcbrakesusa.com
  7. Sep 11, 2022 at 5:35 PM
    16wtundra
    San Diego, CA
    16 CM 040
    Thank you sir.
