EASY Antenna Bezel Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by Slim Gym, May 25, 2023.
  1. May 25, 2023 at 9:53 AM
    Slim Gym
    Slim Gym [OP] New Member
    2013 Tundra DC 4X4
    Came out of the grocery store today to find my antenna mount broken. I searched this site for an hour and could not find the part number for the Antenna Mount for a 2007 - 2013. It is called a "Bezel" on the parts site. Luckily all my other parts to this are not broken. So I only have to replace the "bezel" - what I call an antenna mount.
    Found this good YouTube video on easy replacement of the bezel. As long as you are just taking off the old bezel and putting on a new one - should only take a couple of minutes. If you have to replace the wire from the dash and the mounting nut - My prays are with you.
    How to Fix Broken Antenna Mount with an Antenna Base Mount Replacement on a Toyota Tundra 2007-2013
    https://youtu.be/ExfXhlFHlgg
