Easy 5 min anytime fog light relay mod DIY
Discussion in 'Lighting' started by xtyfighterx, Jan 16, 2018.
  1. Feb 13, 2020 at 11:38 PM
    #181
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    For the SR model which does not come equipped with stock fog switch...you do not need one for this mod (just get a relay). Foglights will switch on depending how you wire it (either to DRL relay ground or aftermarket switch to ground.
    LosGixxer1000 likes this.
  2. Feb 14, 2020 at 12:03 AM
    #182
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    I like your truck. How much did you pay for yours? Thanks
  3. Mar 15, 2020 at 1:41 AM
    #183
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    this worked perfect for me.
  4. Mar 22, 2020 at 11:39 AM
    #184
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Confirmed on a 2016. Worked like a charm.
  5. May 1, 2020 at 9:25 AM
    #185
    fmscott2
    fmscott2 New Member
    I want to add fog lamps to my 2014 SR. I have the wiring behind the lights in the bumper but I don’t have the switch on my turn signal stalk. I am frankly not interested in changing out the stalk since it looks complicated. I want the fogs on whenever I have my parking lights on (when tail lights are on but not headlights) and when my headlights are on. I found this thread and I think all I have to do is buy the lights/bezels, a fog light relay, and a 15amp fuse. Do I simply have to install the lights, hook up the connectors behind the bumper, install the fog light fuse, bend the relay tab, install the relay, and ground the relay bent tab? Sounds too simple LOL
  6. May 1, 2020 at 9:26 AM
    #186
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes except you'll run it to a switch since you dont have the SR5 stock stalk (haha)
    See video
  7. May 1, 2020 at 9:29 AM
    #187
    fmscott2
    fmscott2 New Member
    Why do I need a switch inside the cab if I want the fogs on all the time (except when the lights are in the off position)?
  8. May 1, 2020 at 9:31 AM
    #188
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oops. Tap into your marker light power then ground the relay
  9. May 1, 2020 at 10:53 AM
    #189
    fmscott2
    fmscott2 New Member
    So I don’t need to buy a dedicated fog light relay to use the existing fog light wiring?
  10. May 1, 2020 at 11:17 AM
    #190
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If your rig came with fogs, no. The mod takes places on your factory relay
  11. May 1, 2020 at 12:20 PM
    #191
    fmscott2
    fmscott2 New Member
    I just have the wiring harness for the fogs. I was referring to your comment about tapping into the marker light power. Did you mean the marker light relay?
    I assume the fog wiring harness gets power from the fog relay, so if you don’t have a fog relay installed you’ll need to put one in them do the mod I linked to above.
  12. May 1, 2020 at 12:26 PM
    #192
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Marker light power wire. Find where it's hot and posi-tap it (hate scotch loks). Yes to the fog light relay in the harness if you didnt originally have them. The fog relay will be connected to your 12v power source.
  13. May 1, 2020 at 6:47 PM
    #193
    fmscott2
    fmscott2 New Member
    OK. I think I got it now. Sorry for all the questions. Here’s how I understand it. All I need to do is install the fog lights, install a fog light relay, and ground one of the tabs on the relay. This will make the fogs come on with the parking lights and headlights but will not come on when my light switch is in the off position.
  14. May 1, 2020 at 7:11 PM
    #194
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Its gotta be the right tab on the relay
  15. May 8, 2020 at 11:44 AM
    #195
    fmscott2
    fmscott2 New Member
    Looked in the fuse box and there is no receptacle for the fog light relay (circled red in picture). Where does the other end of the factory fog wiring harness go then if there is no relay receptacle?
  16. Jul 16, 2020 at 5:38 PM
    #196
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    Thanks, I'm gonna try this with my 2020!
    As far as the fog lights going out when high beams are on... Whatever. If the high beams are on, the fog lights aren't gonna help you see shit!
  17. Jul 17, 2020 at 7:43 AM
    #197
    Stig
    Stig New Member
    Fogs help to see far out to the sides which is important especially when making tight turns at night. The only drawback is some people's eyes adjust only to the brighter high beams which limits what they see close up but not everyone has that problem.
  18. Aug 7, 2020 at 10:25 AM
    #198
    Tallyn91
    Tallyn91 New Member
    2014 Super White Tundra SR
    Did you ever figure out an answer to this? Or does anyone know?
  19. Aug 12, 2020 at 1:33 PM
    #199
    ccress83
    ccress83 Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    Just looking out but get rid of those exposed terminals. If any of those touch anything you're gonna have alot of problems probably. I used the plastic insulated ones to do mine. Just a small heads up.
    NewImprovedRon likes this.
  20. Aug 21, 2020 at 9:28 AM
    #200
    fmscott2
    fmscott2 New Member
    I never was able to get an answer so I jerry rigged my fog lights directly to the battery and mounted the switch in a blank panel. Yes, I have to remember to turn off the lights when I park and leave the truck but the install was a helluva lot easier that way. The switch indicator light is bright red and hard to miss when I slide out of the truck.
  21. Sep 26, 2020 at 1:45 PM
    #201
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    What needs to be done for the 2019s to keep fogs on with high beams? Seems like a poster above did this mod on his '19, and ended up with no fogs with high beams.
  22. Oct 11, 2020 at 10:05 AM
    #202
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
    Same here as I would like to have my fogs on with the high beams. I did try this mod but I had the fogs on all the time after turning my truck off. So I would drain my battery with the lights on while the truck is not in use.
  23. Oct 11, 2020 at 10:38 AM
    #203
    Jerry Te37
    Jerry Te37 New Member
    Jerry
    Lapalma ca
    2014 2wd white tundra cm
    Jdm volk racing 20inch te37 Level rear end Morimoto headlight
    Thanks,
    My next mod for sure
  24. Nov 5, 2020 at 8:38 PM
    #204
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    This end up working on the 2020? fogs with DRL's and low beams?
  25. Nov 22, 2020 at 3:19 PM
    #205
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Worked like a charm. I keep forgetting to take a pic.
  26. Nov 22, 2020 at 6:02 PM
    #206
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    Not sure what I'm doing wrong, but I attempted this a few minutes ago and I couldn't get my Fog lights to fire up.
    Maybe it's because my truck is an SR (2021) that didn't come with lights, and doesn't have a switch on the lever?
    I wasn't sure this would make a different though, because if I connect my fog light relay as described in the original post, they come on (and stay on all the time...even when the truck is off, as described by other newer truck owners).
    Any thoughts? If so, please be sure to describe it to me as if I was around 4-years old. :)
    Thanks!
  27. Nov 26, 2020 at 10:18 AM
    #207
    PhearCVBz
    To follow up on my post just above this. I ended up wiring them up like described in this quoted post (to the headlight relay). I couldn't get them to work on my 2021 SR (came without fogs or switch) otherwise.
    Thanks for posting this.
  28. Dec 6, 2020 at 3:43 PM
    #208
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Is there a mod where I can independently control my fog lights instead of it being on all the time? Like only when I turn it on regardless of high or low beam, any ideas?
  29. Feb 4, 2021 at 9:47 AM
    #209
    Billy504
    Billy504 New Member
    Billy
    07 tundra
    My headlight multi switch is partially broke. The headlight part will not turn but my fog lights switch works, is there a way i can do this same setup but instead of using the fog light relay, can i use the headlight relay where when i turn the fog lights on then the headlights turn on also?? 07 limited thanks!!
  30. Feb 11, 2021 at 7:02 PM
    #210
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    I wonder this too. Like a switch(not the stalk) that has ability to turn on/off as you please whether drl/hi/low beam.
