Easy 5 min anytime fog light relay mod DIY
Discussion in 'Lighting' started by xtyfighterx, Jan 16, 2018.
  1. Oct 30, 2018 at 6:50 PM
    #121
    Pudge
    CT
    2015 Blue Ribbon Platinum
    In auto mode, the fog lights will come on when the headlights are triggered to come on. I kinda wanted the fog lights to be on all the time, like when the DRL are on not just headlights. There is a way to do that but its not nearly as easy as this.
  2. Oct 31, 2018 at 6:37 AM
    #122
    WZ KTM
    WZ KTM New Member
    2018 MGM DC TRD Off-road
    I have a 2018 with factory LEDs and 12 volt soulutions remote start setup. No power to fog lights at all. Everything else on the truck works as expected. I’m not say it's because of the remote start I honestly don’t know if they were working before install. Any ideas? I’ve tried every switch configuration possible, swapped relays and tested fuses. I also pulled the fogs out and hard lined them and they work fine. I’m also showing two hot posts in the relay slot. This is driving me nuts. Any help would be much appreciated.
  3. Oct 31, 2018 at 11:30 AM
    #123
    WZ KTM
    WZ KTM New Member
    No fogs whatsoever in any switch configuration. I did speak to 12 volt solutions this morning and they think it could be a bent pin going to the BCM connection. I’ll update later after I mess with it.
    NewImprovedRon likes this.
  4. Oct 31, 2018 at 3:18 PM
    #124
    WZ KTM
    WZ KTM New Member
    7D1AB1B9-86A9-485E-B900-CB608B5CEC80.jpg Success, Tiny little bent post in the BCM plug. Now does anybody have the anytime mod for a 2018?
  5. Nov 1, 2018 at 7:46 PM
    #125
    ToyotaMan
    ToyotaMan New Member
    what is bcm plug?
  6. Nov 2, 2018 at 6:23 PM
    #126
    WZ KTM
    WZ KTM New Member
    The BCM basically controls all your on board electronics. Power windows-door locks-lighting ect. And the remote start harness plugs into it.
  7. Nov 3, 2018 at 1:18 PM
    #127
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Such a quick and easy mod...
    Love this one!
  8. Nov 16, 2018 at 11:46 AM
    #128
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I was messing with this one today and found my 2018 to do the following from factory:
    Headlight switch Off - fogs off
    Headlight switch Auto/DRL - fogs off
    Headlight switch Parking Lights - fogs on
    Headlight switch On - fogs on
    Brights On - fogs off
    I'm actually good with this setup, but was curious if this was different than older models?
  9. Nov 16, 2018 at 11:59 AM
    #129
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    Mine is same. Fogs will turn on under Auto mode if headlights are on.
  10. Nov 16, 2018 at 12:05 PM
    #130
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Cool, and yeah, that's what I meant for the Auto/DRL setting.
  11. Nov 16, 2018 at 12:06 PM
    #131
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Same as my 2010, gotta do Eddies Mod to run fogs without headlights on.
    CMikeB likes this.
  12. Nov 27, 2018 at 1:14 PM
    #132
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    Anyone get this to work on a 2018 with pics of setup?
  13. Dec 1, 2018 at 9:41 AM
    #133
    Squatchtundra
    Squatchtundra Hammer Down
    Olympic Peninsula
    2018 limited cm MGM
    Kings and Total Chaos UCA with ko2's
    Same here...any pics on an '18
  14. Dec 7, 2018 at 8:39 PM
    #134
    jcotoole
    jcotoole New Member
    2019 LTD DC magnetic grey
    I have a 19’ Ltd. On mine it’s negatively switched too. When I do your method the fog lights stay on permanently - even when ignition is off. So I hooked the fogs to the drl relay and they stay on only when the drls are on. ( I want the fogs on all the time) so I hooked them up to my headlight relay. They come in with low and high beams but not drls. I’ve got to get my meter from my other house to figure out a negatively switched relay. Another know of one??????
    Tundra18ttags likes this.
  15. Dec 8, 2018 at 3:49 PM
    #135
    epa4wd
    epa4wd New Member
    Ed
    Would have to see how you wired it up. Mine would only come on if the headlights were on since the headlights were negatively switched also.
    Regards
    Ed.
  16. Dec 10, 2018 at 8:04 PM
    #136
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Thanks to the op. Was too easy.
  17. Dec 18, 2018 at 6:36 AM
    #137
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Wanting to do the Anytime mod to my 2017 CM Limited, but want to keep the stalk switch to turn them on. No need to tun them all day in sunshine when the DRL's are on as well.
    CMikeB likes this.
  18. Dec 18, 2018 at 11:33 PM
    #138
    jcotoole
    jcotoole New Member
    I wired them as the 5 min mod as above. I bent the pin over, and connected a wire to ground. They stayed on at all times even with ignition turned off.
  19. Dec 24, 2018 at 4:03 AM
    #139
    Ikonrat
    Ikonrat New Member
    Thats what happened on my 2018, stayed on even with key removed.
  20. Dec 24, 2018 at 5:41 AM
    #140
    epa4wd
    epa4wd New Member
    Ed
    If you wire them up as the first post of the OP, yes they will be on always as its neatively switched. I wired mine to negative pin of headlight relay.
    Motomoose68 and Ra1dercak3 like this.
  21. Dec 24, 2018 at 8:14 AM
    #141
    jcotoole
    jcotoole New Member
    Hey thanks for the info. I did wire it up to the headlight relay and as well but when the headlights are off so are the fogs. I then wired them up to the drl relay and the fogs only turn on in drl mode and turn off when the headlights come on.
  22. Dec 24, 2018 at 8:31 AM
    #142
    Professional Hand Model
    Hand Protectors
    Cool write up! First Gen’r here and experiementing with the same mod. Our Under Engine Fuse Box is a little different. Anyone have experience with pulling these Relay Switches out?
    Tried wiggling and pull method. Wisdom says stop. Visual inspection shows 4 clips on the fuse housing. Need a special tool?
    Also, underneath the fuse housing there are 2 clips holding the base in place. Another special tool?
    Tried prying clips (4) and (2) but too tight of space to lever any actionable results!
  23. Dec 28, 2018 at 2:37 AM
    #143
    Ikonrat
    Ikonrat New Member
    As good as it gets for now. Thanks epa4wd! I wired as you have on my 2018. I now have fogs in high beam which was my main goal. I have fogs on in high beam, regular headlights, and auto mode (when headlights auto on). No fogs in Parking light mode or DRL. Prefer the fogs to also be on in parking mode, but I'm fine with it for now. Thanks again!
    epa4wd[QUOTED] likes this.
  24. Dec 28, 2018 at 8:46 PM
    #144
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    What happens if you ground both the headlight and DRL relays in 18-19?
  25. Dec 30, 2018 at 8:31 PM
    #145
    epa4wd
    epa4wd New Member
    Ed
    Then you would be grounding also the headlights to the DRL, headlight would turn on with DRLs.
  26. Dec 30, 2018 at 9:43 PM
    #146
    bmcdds
    bmcdds New Member
    CA
    Thanks, makes sense now.
  27. Jan 3, 2019 at 11:50 AM
    #147
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    This is the best way to do this. WOuld you happen to have a write up on how you connected to the wiring connector? can you use this button and hit the button to turn on the fogs with just the ignition on and turn them off with the ignition on?
    OBXTundra[QUOTED] likes this.
  28. Jan 3, 2019 at 11:55 AM
    #148
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Fogs work with parking lights, low, and high. Will not work with just ignition on.
    Used a quick-tap for the illumination wire. Didn't mess with the actual harness.
    Norfolk757 likes this.
  29. Jan 3, 2019 at 12:01 PM
    #149
    Norfolk757
    Tom
    Norfolk, VA
    That makes sense.. They will only come on when the parking lights are turned on. I would like to see how I can get them to turn on without turning on the parking lights, but in retrospect, it would be best to have the parking lights on while the fogs are on so the warning sound let me know the lights are on. Nevermind, your option is the best one. So you actually ran the bent tab Neg wire to the black, the green to the negative, the blue to AC wire for the illumination of the dash, and blue to a constant positive with a fuse?
    payyourtoll and OBXTundra like this.
  30. Jan 3, 2019 at 4:53 PM
    #150
    OBXTundra
    OBXTundra Member
    Southeast USA
    -bent the tab on the fog relay.
    -ran a wire from the tab through the firewall to the switch inside the cab.
    -ran a wire from the opposite switched wire to a ground (bolt) on the dash.
    -ilumination wire just goes directly to switch.
    This will depend on the switch you get and exact wire colors/configuration. The switch is just opening and closing the ground of the relay, it is not carrying the load of the fogs themselves.
    Norfolk757[QUOTED] likes this.
