EAG raptor conversion replacement grille
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kdgcng, Jul 29, 2017.
  1. Sep 10, 2019 at 12:31 AM
    Big_Red
    Big_Red 2015 limited CM TRD
    15 Radiant Red Limited CM 4x4
    2” level with 5100 billies, 295x70x20 nittio ridge grapplers
    16FC7482-2F0A-49C0-BEE2-CDE7A28EEC0C.jpg Matte black wired the leds in to the low beams. Just for now with an add a fuse. I can’t buy time and to cheap to take it in for some one to do what I can when I get the time.
  2. Sep 11, 2019 at 9:41 AM
    fmscott2
    fmscott2 New Member
    What size fuse did you use? I’m putting in a 4 since they’re LED and shouldn’t draw much power at all but I’m no electrical engineer. Where and how did you land the ground wire?
  3. Jan 17, 2022 at 10:55 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Bringing this one back. Anybody know where to get replacement LED lights? One of mine fizzled out.
  4. Jan 18, 2022 at 4:20 AM
    fmscott2
    fmscott2 New Member
  5. Jan 18, 2022 at 12:47 PM
    Tundyfundy
    Bay Area, CA
    Thank you! I saw these but the reviews were really mixed. I was hoping someone had a line on the same ones that are in the grill. I contacted the manufacturer but haven’t heard back. I’ll probably try these if they don’t respond
  6. Jan 18, 2022 at 12:59 PM
    fmscott2
    fmscott2 New Member
    The lights that came in the grill are probably the same garbage lights as those on Amazon. The screws on my grille are all rusted to hell.
  7. Jan 18, 2022 at 1:01 PM
    Tundyfundy
    Bay Area, CA
    Wow. I live in Cali and I don’t have any rust. I’ve had the grill over a year And a half and have taken it on many trips through bad weather. For its position on the truck I’m happy that they lasted that long. I plan on weather proofing the new lights with some silicon and heat shrink to see if I can get some more life out of them
