e-brake on half way when pulling boat up ramp god or bad?
Discussion in 'General Tundra Discussion' started by Rnowlin, Mar 10, 2020.
  1. Mar 10, 2020 at 11:20 AM
    Rnowlin
    Rnowlin [OP] New Member
    Richard
    2011 DC
    trd sway airbags
    I have a 2011 dc with the lil v8 and I tow a 5k boat. I was told to set my e-brake half way when pulling the boat out of the water. I remember this trick with old limited slip rear ends but does it work with the tundra's modern traction control ?
  2. Mar 10, 2020 at 11:45 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Don’t know the answer but I’m curious to see what people say.
    15whtrd likes this.
  3. Mar 10, 2020 at 11:47 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thats basically how our auto lsd works. Braking force on the rotors “tricks” the diff to think tire still has traction.
    I can’t imagine it working as well as our abs activated system will
  4. Mar 10, 2020 at 11:51 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I assume you have a 2wd. (Otherwise use 4wd).
    I have never used that trick, but I agree with Jeff above. On my 1st Gen 2wd I had all my boat passengers sit in the bed for traction. Otherwise my tires would spin. Much better with my 3rd Gen 4x4. No more offending my wife's friends by saying I need their weight for traction. :rofl:
  5. Mar 15, 2020 at 7:24 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    When you lose traction your power is released through one wheel and the other stops turning ( unless you have locked diffs). To prevent that, an old school trick would be to set the e brake so if you lost traction, the one spinning tire is restricted somewhat and that energy is transferred to the non spinning wheel. It can work, but it’s harsh on your whole system. Toyota has some technology on the newer gens that Mimic this using the brakes auto lsd I think?? Your doing the same thing just manually. You may have this technology now but you’ll have to research you year truck as I can’t say for sure. The best would be a locking diff so both tires spin at the same rate no matter what. Second best is a true LSD.
  6. Apr 15, 2020 at 6:59 AM
    Rnowlin
    Richard
    2011 DC
    trd sway airbags
    Yes I do have the auto lsd and traction control automatically kicks in and stays on if it keeps slipping. It does seem to help with the e-brake on just a bit though. when they open the state again I will try it with the lsd turned on and no ebrake. and see how that works. most of the time it's not a issue but some of the ramps here in Central Texas are steep and my boat is 5k+ without the trailer. thanks guys stay safe and well!!!
    Tundyfundy likes this.
  7. Apr 15, 2020 at 8:18 PM
    Tundyfundy
    Bay Area, CA
    You too brother. Thank you have a great evening.
