Dumb question - service intervals
Discussion in '3rd Gen Tundras (2022+)' started by flatlandclimber, Oct 5, 2022.
  1. Oct 5, 2022 at 7:37 PM
    flatlandclimber
    flatlandclimber [OP] New Member
    2022 DC
    So... I've made it to the ripe old age of 46 (trust me - it wasn't planned) without taking vehicles to mechanics or buying a vehicle under a warranty.
    I ruined that streak earlier this year, and find myself with a Tundra coming up on 5000 miles, the first service interval.
    It's kind of inconvenient this week, and next week we are going on a bit of a trip that will add another 700 or so...
    Any downside to doing the 5k service at 5600 or so?
    Humor me. It's my first new vehicle.
  2. Oct 5, 2022 at 7:51 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I think you will be perfectly fine for your trip, but I personally like to change the initial break-in oil at about 1k., then 5k intervals after that, but I'm older and a little anal. :)
    BravoDeltaRomeo, ColoradoTJ and Kap1 like this.
  3. Oct 5, 2022 at 7:54 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Isn't the regular oil change as per Toyota is 10k miles? That's in the manual, so you should be just fine.
    I will do my oil changes every 5k miles though
  4. Oct 5, 2022 at 7:59 PM
    flatlandclimber
    2022 DC
    I'm changing the oil before we leave.
    Oil is cheap, engines aren't. My '89 pickup went a half million miles for a reason.
    Thanks!
    ColoradoTJ, Kap1, TILLY and 1 other person like this.
  5. Oct 5, 2022 at 11:57 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    Miss your oil change, you might void your warranty.
  6. Oct 6, 2022 at 12:49 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    TTV6, you should change every 3k.
    07DCLimited and ColoradoTJ like this.
  7. Oct 6, 2022 at 2:44 AM
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    Why is that??
    ColoradoTJ likes this.
  8. Oct 6, 2022 at 3:37 AM
  9. Oct 6, 2022 at 4:00 AM
    nodak67
    nodak67 New Member
    JR
    well depends on the vehicle cycle.
    normal duty was 10k miles (5k for rotates) for LOF and abnormal duty was 5k LOF.
    on the FFV v8's it was 5k regardless even if you didnt use flex fuel per the service manual but the non flex v8's were 10k.
  10. Oct 6, 2022 at 4:02 AM
    nodak67
    nodak67 New Member
    JR
  11. Oct 6, 2022 at 5:18 AM
    JoeInMinn
    2022 1794 Trd
    Not trying to start an issue , but that's a filter manufacturer I am sure they would love more oil changes.
    Also my years of experience in fleet maintenance , engine rebuilding ect tell me real world that's not needed. I believe service manual for the Tundra 3.5 says 5k under sever conditions and 10k normal. Those number seem pretty good to me on full synthetic. Castrol labs does all my testing for me on my fleet, I will be sending them samples from he Tundra, who knows I may be wrong. I will certainly post the details here.
    Also I just do not see why everyone sees a turbo and thinks you need to baby an engine, yep they do break so does everything else. But the most abused engines in the world have been running them forever.
    mike220022 likes this.
  12. Oct 6, 2022 at 8:04 AM
    Water cooled helps controls temps, but oil quality still applies.
