Dual rears
Discussion in 'Suspension' started by JROCK915, Mar 3, 2015.
  1. Mar 3, 2015 at 5:54 AM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    I'm thinking about a rear, dual shock set up. Any ideas on how to mount the aditional shock?
  2. Mar 3, 2015 at 9:11 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    1 question.... why? I thought dual(or triple or quadruple) shocks died in the 90's
    Only time an extra shock is warranted is on a full on long travel truck where the additional shock allows for softer dampening to resist fade longer, or if a bypass is being added
    MotoTundra and JROCK915[OP] like this.
  3. Mar 3, 2015 at 10:30 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Are you trying to get a better ride or lessen the sag when you tow? Or both? Maybe airbags?
    JROCK915[OP] likes this.
  4. Mar 3, 2015 at 5:47 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    @Relentless , you answered my question. never put two and two together when I saw it they're usually doubled up with long travel. I knew I was missing something. If I need to add any extra ass for towing, I'll do either airbags or helper springs.
    FunkinTundra and Relentless like this.
  5. Mar 3, 2015 at 6:42 PM
    Mike Tread lightly.
    south carolina
    IMO air bags would be a better choice for towing or heavy hauling... they can transfer the load to the axle better..
    Relentless and JROCK915[OP] like this.
  6. Mar 3, 2015 at 6:45 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Good to know. We haul often. When we do, it's w/ a full bed too. Also, plan on adding a topper.
  7. Mar 3, 2015 at 6:53 PM
    Mike Tread lightly.
    south carolina
