Dual Battery Question
Discussion in 'General Tundra Discussion' started by Jrharvey02, Oct 26, 2018.
  1. Jul 9, 2019 at 4:10 PM
    Jrharvey02
    Jrharvey02 [OP] New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    There’s nothing more involved than running a 0 gage wire from your engine battery positive to the new ones positive. From there, you ground out the negative of the new battery somewhere (frame), my ground is done w/ 2 (yes two) 4 gauge wires, I believe. Mine was done by CarToys. I would never recommend them after having to redo most of their work.
    Stewartac likes this.
  2. Aug 7, 2019 at 5:22 PM
    rodm1
    rodm1 New Member
    I need to figure out something before my battery go bad.
  3. Aug 8, 2019 at 7:41 PM
    Stewartac
    Stewartac New Member
    Castle Rock Colorado
    2013 White Tundra
    If it's charging you should have more than 14 volts on the second battery when the truck is running
