DTE (distance to empty) indicator on Tundra 2017 limited?
Discussion in '2.5 Gen Tundras (2014-2021)' started by VAQuicksand, May 22, 2017.
  1. May 22, 2017 at 4:44 AM
    VAQuicksand
    VAQuicksand [OP] New Member
    Can someone tell where to view the DTE indicator on a 2017 Tundra? Does it even have one?
  2. May 22, 2017 at 4:46 AM
    wspearce3
    wspearce3 New Member
    Will
    2023 Platty
    On my 2014 you have to press the settings button on the steering wheel multiple times for it to show up on the display on the dashboard next to your tach and speedometer.
    tomsinamerica likes this.
  3. May 22, 2017 at 5:23 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    yes, there is one...press the button on the steering wheel to scroll between: DTE, MPGs, Brake controller screen, and Trip time. I may be forgetting something, I leave mine on DTE, so I don't scroll much.
  4. May 22, 2017 at 5:28 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    if i remember correctly it's basically just a "distance until the fuel light indicator shows up" which in itself is way premature an inaccurate.
    gosolo likes this.
  5. May 22, 2017 at 5:28 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    The low fuel light comes on around 20-30 miles DTE. At that point, if you fill up, you'll only get about 31-32 gallons in. The Tundra has about a 6 gallon reserve to keep the fuel pump cool.
    Here's a pic.
  6. May 22, 2017 at 7:16 AM
    VAQuicksand
    duh.... found it! Thank you all for the advice
  7. May 23, 2017 at 12:57 PM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    How accurate is the DTE reading? When you hit "empty," do you always put in 31-32 gallons or does it vary?
  8. May 23, 2017 at 1:10 PM
    VAQuicksand
    sorry, can't answer that. i haven't let go to "empty".
  9. May 25, 2017 at 8:21 AM
    vangx913
    vangx913 New Member
    Lee
    15 Magnetic Gray SR5 CM
    When I first have the truck, it always show 400 miles/tank. But I let the truck run until gas light show up once. I only see getting 345 miles/tank.
