DSR1 compatibility
Discussion in 'Audio & Video' started by budjb, Dec 11, 2018.
  1. Mar 11, 2019 at 6:14 PM
    Cfincke
    San Antonio
    I researched for a while, went to and listened to a $2k package by one company. After lack of communication back from the company over a weeks time, I messaged Tech12volts on a Sunday afternoon, a few back and forth emails over 30 minutes I had ordered everything I needed. I gave James a budget I wanted to stay in and info on how I wanted it to sound, i would say he nailed it. It was as smooth as ordering an exhaust from Keith at Dirty Deeds.
    I as a customer had a say in what I wanted the sound to be and I was recommended a few options. I appreciate that James builds his sub boxes here in the USA as well.
    afbatts, rollin-on-dubs and phogallen like this.
  2. Mar 11, 2019 at 6:53 PM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    You put it in yourself?
  3. Mar 11, 2019 at 7:52 PM
    Cfincke
    San Antonio
    Yep, I did a small write up in my build thread on my install. It is not hard, just take your time
  4. Mar 15, 2019 at 10:06 AM
    bard0117
    bard0117 New Member
    Anybody got anymore screenshots as to how to program the DSR1? The previous ones were perfect but I'd like to see if anybody has any more input.
  5. Mar 15, 2019 at 10:11 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    What do you gain by installing the sound deadener on the doors?
  6. Mar 15, 2019 at 10:13 AM
    bard0117
    bard0117 New Member
    My friend has this installed and it's an absolute must once you install an amp and new sub/speakers. That's my next buy.
  7. Mar 28, 2019 at 11:40 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Did you keep all the stock speakers or did you replace those too?
  8. Mar 28, 2019 at 1:49 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Replaced them all with JL C2 components and sound deadened all doors, inner and outer skins.
  9. Mar 28, 2019 at 3:01 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    I noticed a massive increase in sound quality just by using one box of NOICO 80mil sound dampener. I used it on my doors, some spots on the floor, the rear wall and the frame inbetween the front and rear door. I still have two pieces left to add to my roof when I get a free weekend. I applied more to my front doors than the rears and I'm really happy with the results. The road noise doesnt appear to be as bad.
    Im thinking in the Fall that I am going to add some MLV (mass loaded vinyl) and CCF (closed cell foam) to the entire floor. That will be it for sound deadening for me. I think.
  10. Jun 9, 2019 at 12:03 AM
    rollin-on-dubs
    rollin-on-dubs New Member
    Chuck
    Middle TN
    2014 CrewMax Platinum
    Toytec Boss Suspension SPC Light Racing UCA's Coach Builder 3" Rear Shackles 20x9 Fuel Boost 275/60/20 Nitto Terra Grappler G2 Locker-Down Center Console Safe Morimoto XB LED Fog Lights Ellis Precision Shift Knob Ellis Precision Battery Hold Down
    @phogallen do you have any screen shots of the settings used on the dsr1? Particularly the one for what speaker layout used (screen with car and speaker placement).
    Thanks, I have the same setup and wanting to change to the dsr1.
    Do your new dash speakers run off the HU or the JL amp?
    Thanks!
  11. Jun 10, 2019 at 4:00 PM
    tundraal
    tundraal New Member
    I've heard from some SQ guys that it is best to set time alignment first. Then set EQ to flat and play pink noise. Play the pink noise at your normal listing level (it's probably going to be really loud). Try and have the RTA in your listing position. Remember to try and only cut the peak frequencies and not boost any if you don't have to. When I first tried it, I time aligned last and it sounded flat like an AM radio. But once I time aligned first and then EQ'd out some of the peaks, all sounds really good now. One thing that helped me was to run all new speaker wire. I think the factory wire, with all the molex connections and small gauge, was causing some phase shift.. Or it just couldn't handle the 100+ RMS I am sending to my mids and tweeters. I couldn't ever seem to get a solid center image on vocals. They would just be sort of all over the place, but now the vocals are dead center. Hope this helps.
  12. Jul 3, 2019 at 7:16 AM
    Jai LI
    Jai LI New Member
    TX
    2018 CM 1794 5.7 4x4 FFV
    Rear sway bar, CAI and sound deadening
    I currently have the ReCurve (********* setup) in my CM (1794 w/JBL). Kept the HU and the stock amp. Sounds good, except it's really lacking mids. I've done the sound deadening all over, except the roof.
    Those of you with the DSR1, would you say if I replaced the Recurve with the DSR1 would help me to get more mids? Or, would I be better off getting a new head unit?
  13. Jul 3, 2019 at 8:35 AM
    Jai LI
    Jai LI New Member
    TX
    He did, I just wanted to gauge user experience. If nothing else, the bluetooth app looks super cool.
  14. Jul 3, 2019 at 10:26 AM
    tundraal
    tundraal New Member
    Lacking mid range (vocals) or mid bass? What speakers are you using? I am not sure how many watts the stock amp outputs, but most are usually only 20-30 watts. The best way to diagnose is to use an RTA (you can download app to your phone). Play pink noise through the system and see what sort of response you are getting. You likely have peaks and valleys that need to be adjusted.
  15. Jul 3, 2019 at 10:35 AM
    Jai LI
    Jai LI New Member
    TX
    I've installed the Tundra TT65CS Front Door and Rear door component with the TXD8005 5 CHANNEL AMP *********) and 12" sub w/ box.
    Sounds great, except not enough mids for my liking. I "think" each component set is receiving 75w and the sub is getting 100w.
    I'll definitely look into your suggestion, RTA. I tuned the amp and Recurve based on their videos. I was contemplating taking it in and getting it professionally tuned.
    Lacking mid bass
  16. Mar 2, 2020 at 2:34 PM
    Sweepcity
    Sweepcity New Member
    Jeff
    2016 tundra limited
    Maybe my question can be answered here if it’s not the right thread please point me in the right direction. I have 2016 tundra limited with JBL. I want to upgrade everything behind the hu, but I want to do it in stages. My question is. Will the DSR 1 work as a stand-alone unit meaning regular functions of everything with just the DSR1 no amplifiers no speaker upgrades . And of course at a later date upgrade amplifiers speakers sub? I am having a hard time finding answers to this question. Someone please help.
  17. Mar 2, 2020 at 3:45 PM
    Cfincke
    San Antonio
    The DSR1 is just a sound processor, it will not provide any signal to the speakers.
    here is a simple signal diagram if keeping the JBL head unit
    head unit -> DSR1 -> amp(s) -> speakers
  18. Mar 2, 2020 at 4:22 PM
    Sweepcity
    Jeff
    2016 tundra limited
    Ok thanks that answered my question completely thank you. I know it is not an amplifier but I thought that it would be a replacement for the amp with a plug in to the speakers that could be swapped for a separate plug with rca jacks but it is crystal clear now. It’s sounding more and more like my option to upgrade the sound quality can be done in stages as far as the purchasing, but as far as installation it’s all or none. Thanks for the info.
  19. Mar 3, 2020 at 5:43 AM
    #49
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Random thoughts !
    I had to read your post twice because I originally missed the part where you said you had the recurve, then I really chuckled at the fact I also missed the part where you kept the factory amp.
    BTW - Im laughing at myself, NOT YOU ! - Guess I wasnt paying attention TWICE...
    Maybe others will shed more knowledge on this, but isnt the problem you are experiencing caused by the factory amp? I considered that kit you have but ended up going a different route when I did mine.
    The recurve has a built in DSP and "they" provide tuning instructions. Have you tuned according to those instruction? and, what about getting the matching PNP AMP and harnesses and get rid of the factory amp?
    You already have over half of "their" system, why not finish it off and see where you are, before introducing another brand into your current setup?
    Those with way more experience than I - please correct me if Im wrong - But isnt the amp the major source of contention in our trucks regardless of JBL or Non-JBL?
  20. Mar 26, 2020 at 10:42 PM
    #50
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    What frequency is your amp crossover set at ? You try lowering it?
  21. Mar 27, 2020 at 5:29 AM
    #51
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Disclaimer - I'm not an expert and open to all ideas but here are some thoughts.
    1. I have Hertz K170's in the doors and a JBL Club WS1000 all hooked up to am Infinity Kappa 5 amp. I set the four K170's to the high pass filter and set the x-over (it's set at 12dB/Oct) at about 110Hz - this is double the lowest frequency range of 55Hz for the K170's. The sub is then set to low pass filter and the x-over is at about 100Hz. The idea is at 12dB/oct the rolloff for sub and K170's will overlap just enough to give a flat response in 100-110Hz range.
    2. The biggest improvement in my midbass was after properly adjusting the gains to the K170's. I used an SMD DD-1 distortion detector which allows you to find the exact point where the amp starts to produce distortion and then you back off a little - allows you to get the most out of the amp. Adjusting the gains has much more effect on their lower frequency output than there higher frequency output. In other words the midbass got significantly louder with the gain increased than the highs. Makes sense as I believe it requires a lot more wattage to move a woofer than a tweeter.
  22. Mar 27, 2020 at 10:25 AM
    #52
    Sleeper16plat
    Near Vancouver
    Try setting the crossover frequency to 80Hz for both the sub and speakers. This will send a little more to the K170's and give you the mid bass you are missing!
    PWMDMD likes this.
  23. Aug 29, 2020 at 2:58 PM
    #53
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Anyone have any problem with the DSR1 - RD900/5 amp and the new JBL head unit in 2020s? I've got that setup and having a couple of issues: (1) some of the Carplay features (verbal instructions on Maps, for example) doesn't work and (2) on occasion, the head unit doesn't have any sound and the truck has to be restarted and it works fine. Any ideas?
    PWMDMD likes this.
  24. Aug 29, 2020 at 3:00 PM
    #54
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    I don't use voice commands but yes to no sound sometimes. You do not need to restart the truck...just hold the volume knob down to force the HU to restart and when it boots up there will be sound. Once or twice I had to reboot the HU twice before there was sound. Just one more reason I'm waiting for the next generation of aftermarket HUs and then I'll replace the stock unit and won't need the DSR-1.
  25. Aug 29, 2020 at 3:09 PM
    #55
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    DSR 1 is the worst piece of stereo gear ever, from programming to hardware. Good luck trying to get it work right on a 2020. I re-programmed mine 3 times now and gave up. Ripped it out. Have the same issues you’re having with voice prompts. And with no music playing, there are plenty of floor noises. Can’t stand it.
  26. Aug 29, 2020 at 3:29 PM
    #56
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    To me, the DSR-1 is just a necessary evil if you want to keep the stock HU. It's not perfect, it gets the job done, but a good aftermarket HU without a DSR-1 is superior.
  27. Aug 29, 2020 at 5:21 PM
    #57
    MGMTundra251
    Far from perfect. Pay $300 and get stuck with issues and headaches. No thanks. A better solution would be the PAC Amp pro. I just installled it in my ES 350 with zero issue. I didn’t have to program anything, it’s just plug and play. All of my voice prompts works and no floor noise at all. There is even an option for a toslink cable that is not susceptible to noise. They have it figured out compared to the junky DSR-1. Unfortunately they only have a unit for 2019 and older tundra. They are still working on the unit for the 2020 Tundra.
  28. Aug 29, 2020 at 6:21 PM
    #58
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    There's the rub...a nonexistent product is not helpful. Hopefully, this will come to fruition and be another option for people who want to keep the stock HU.
