Drum brake kit has 2 different drums?
Discussion in '1st Gen Tundras (2000-2006)' started by Zach_795, Jan 21, 2023.
  1. Jan 21, 2023 at 11:29 AM
    Zach_795
    Zach_795 [OP] Master Apprentice
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k
    I recently ordered the PowerStop KOE15314DK rear brake kit for my 02 Tundra. When I took the drums out of the box I noticed that one drum had a smooth finish while the other still had a rough finish on the exterior, both insides are the same. Both boxes have the same part number and UPC. Are they supposed to be this way? Does one go on the driver side and one for passenger? I included pictures for reference. (I already painted the drums so it’s a little harder to tell)
    Any help is greatly appreciated! :)
  2. Jan 21, 2023 at 11:45 AM
    2mchfun
    Looks like they were each simply cast using different molds. The machined surfaces are or should be really close to identical.
  3. Jan 21, 2023 at 11:47 AM
    2mchfun
    Welcome to the forum from OKC!
  4. Jan 21, 2023 at 12:27 PM
    Dirtrcr13
    Dirtrcr13 New Member
    Jerm
    03 Tundra// 16 4Runner
    There was an update in August of '02 for the 03+ model. Can not remember the exact specifics but the newer stuff is fine for the older models but not the other way around, so you should be ok, even if its mismatched. I did the same thing last spring and had to return the drums. I have a 03 AC that was built in August of 02 (yeah, couldnt have made it easy for me in that sense) and it had the update...
  5. Jan 21, 2023 at 12:47 PM
    2mchfun
    Assuming you already know, but maybe not. The threaded holes allow you to use bolts as a pushing force to remove the installed drums which in many cases require some effort to get worked off. If you run bolts in those holes gently while tapping on the drum with a hammer they should slowly come off. PB blaster or other penetrating oil won't hurt either.
  6. Jan 21, 2023 at 12:56 PM
    Zach_795
    I won’t be the one doing it :spending:
    2mchfun likes this.
