Drop some knowledge....
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Jan 24, 2017.
  1. Mar 1, 2017 at 7:25 PM
    #901
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Damn, we be dropping the knowledge tonight.
    Good stuff
    mdavis likes this.
  2. Mar 2, 2017 at 12:13 AM
    #902
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    Its not that the water will go bad, but that the bacteria and or algae that is introduced during the bottling process will have enough time to grow to the point that it can be harmful.
    Also if we took the bacteria out of the equation, if the bottles are exposed to heat or UV light then the plastics begin to break down and you end up consuming them.
    driverdog likes this.
  3. Mar 2, 2017 at 3:53 PM
    #903
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    FALLING IN ICY WATER
    Joe Alton has a few bits of advice which make a lot of sense for preparing for this situation:
    • Keep a change of clothes handy that is kept in a waterproof container
    • Have a firestarter that works when wet
    • Have blankets
    • Look for the clearer blue areas of ice (thinner ice tends to be darker)
    • If you fall in, try to stay calm and slow down your breathing to prevent panic
    Alton continues his advice for what to do if you fall in:
    Start by holding your breath and getting your head out of the water. Once you’ve done so, inhale deeply and bend backward. Turn your body in the direction of where you came from; you know the ice was strong enough to hold you there. Tread water and quickly get rid of any heavy objects that are weighing you down. Keep your clothing on, though. It has air pockets between the layers that are helping you stay buoyant.
    Now, try to position your body as horizontally as possible and lift up out of the ice using your hands and arms. Keep your arms spread in front of you to help distribute the strain on the ice. Kick with your feet to gain some forward momentum. At the same time, try to get more of your body out of the water. The more of your body that’s out of the water, the better. Cold water drains body heat much faster than cold air. Allow a few seconds to let water drain from your clothes; it’ll make you lighter.
    Some of the ice may crack but keep moving forward. An ice pick would help gain a handhold (another good reason to have one handy in icy conditions).
    Lift a leg onto the ice and then lift and roll out onto the firmer surface. Do not stand up! Keep rolling in the direction that you were walking before you fell through. This will spread your weight out, instead of concentrating it on your feet. Then crawl away until you are sure that you’re safe.
    Start working to get warm immediately by removing wet clothes and getting out of the wind. Extra clothes from your or a party member’s backpack should be put on immediately.
    Alton also recommends working with someone else instead of trying to make a go of it alone. There truly can be safety in numbers.
    Wynnded, mdavis and driverdog like this.
  4. Mar 2, 2017 at 8:02 PM
    #904
    TXMiamiFan
    Jose
    Boobytrap spelled backwards is "partyboob"
  5. Mar 2, 2017 at 8:10 PM
    #905
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    What I was going to say...algae and plastic leaching chemicals into it.
  6. Mar 2, 2017 at 8:15 PM
    #906
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Spanish moss is actually in the pineapple family
  7. Mar 3, 2017 at 4:27 AM
    #907
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    That's a mudflap
    Thegr8punkin likes this.
  8. Mar 3, 2017 at 5:06 AM
    #908
    Krohsis
    Krohsis New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    A human eats over 7 pounds of feces over a lifetime.
    ColoradoTJ[OP] and Thegr8punkin like this.
  9. Mar 3, 2017 at 5:30 AM
    #909
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No shit? Wait...
  10. Mar 3, 2017 at 5:46 AM
    #910
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    You can blame New Jersey for the expiration date on water. http://www.primermagazine.com/2010/...hy-does-bottled-water-have-an-expiration-date
    ColoradoTJ[OP] and driverdog like this.
  11. Mar 3, 2017 at 6:57 AM
    #911
    TXMiamiFan
    Jose
    No wonder I can't get rid of the last 7 lbs to get to my ideal weight.
  12. Mar 3, 2017 at 8:16 AM
    #912
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    It's bc your diet is.... shitty :rofl:
    Okay, that's my one pun for the year.
  13. Mar 3, 2017 at 8:39 AM
    #913
    TXMiamiFan
    Jose
    I think you're full of shit!
    Ha, used mine.
  14. Mar 3, 2017 at 8:59 AM
    #914
    sawzalot
    sawzalot New Member
    14' Tundra D Cab 4x4 4.6 L
    Tonneau Cover
    The cigarette lighter was invented before a match.
  15. Mar 3, 2017 at 9:01 AM
    #915
    sawzalot
    sawzalot New Member
    Tonneau Cover
    A good one for our significant others- Most lipsticks contain fish scales , yummy .
  16. Mar 3, 2017 at 10:37 AM
    #916
    TXMiamiFan
    Jose
    I see this thread going to "shit" very quickly . . . LOL
    Krohsis and NewImprovedRon like this.
  17. Mar 3, 2017 at 1:11 PM
    #917
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Is this why so many women are 'bat shit crazy'?
  18. Mar 3, 2017 at 2:07 PM
    #918
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Stevie wonder could count the ridges on the dime;)
    NewImprovedRon likes this.
  19. Mar 9, 2017 at 8:00 PM
    #919
    gjbsupCM
    gjbsupCM New Member
    Glen
    Hilton Head, SC.
    21’ SR5 XSP Crew Max
  20. Mar 10, 2017 at 12:47 AM
    #920
    Nor7
    FYI: You can find a flux capacitor on OReily's website. Product number: 121G
    landphil and Tundra Fan like this.
  21. Mar 10, 2017 at 7:50 AM
    #921
    TXMiamiFan
    Jose
    How would anyone know this; is this your new future mod? :D
  22. Mar 12, 2017 at 10:32 PM
    #922
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    :D That's cool
    It's even made by EB Enterprises. (Emmet Brown) :cool:
    Props to O' Reilly
  23. Mar 14, 2017 at 10:02 PM
    #923
    I know for a fact, this guy gets no play:
    Straight piped exhaust out of hood, Bro bar....yeah.
  24. Mar 14, 2017 at 10:44 PM
    #924
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    The "stop" on a dog is located inbetween the muzzle and the skull. Or right between the eyes.
    TXMiamiFan and NewImprovedRon like this.
  25. Mar 14, 2017 at 10:52 PM
    #925
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    That looks like a tankless water heater with some glow sticks! It's not going to get you far into the future.
  26. Mar 14, 2017 at 10:58 PM
    #926
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Is that an old Isuzu? They had diesels in those. Maybe he's got a giant turbo hiding under that stack. You know that that's your duramax's little brother don't you Chris?
  27. Mar 14, 2017 at 11:13 PM
    #927
    Yep, 91-94' Isuzu. Lol
    This guy drove off, it was a straight piped 4 cylinder and an empty front seat. It was so loud!!!
  28. Mar 14, 2017 at 11:25 PM
    #928
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Dang, I was hoping you were going to say that when he took off he was huffing a big cloud of 4 cylinder turbo diesel exhaust. So, the race stickers are just for show as with the stack. Wonder what happens when it rains. Do you think he's got a drain on there? Or does it burble like it's under water?
    ColoradoTJ[OP] likes this.
  29. Mar 14, 2017 at 11:35 PM
    #929
    I'm sure water getting into the exhaust is the least of his concerns. Lol. I was wondering the same thing.
    I bet he gets tickets all the time for that loud ass exhaust. Police are tough on noisy fartcan exhausts in this city. Hell, I was warned a few times with a corsa exhaust on my Trans Am. It was loud though. I almost put a Billy Boat exhaust in my Corvette, but changed my mind after driving a couple other cars with that exhaust.
    I must be getting old. I like having a quiet cabin so I can crank up the music.
    Joeshaker[QUOTED] likes this.
  30. Mar 14, 2017 at 11:39 PM
    #930
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I knew a guy back in the 80's that wanted his vette louder so he took an ice pick to the muffler. Sounded like busted up glass packs!
