DRL help
Discussion in 'Lighting' started by Prostar 190, Dec 15, 2017.
  1. Dec 15, 2017 at 6:26 AM
    I have a 2010 Limited that didn't come with the amber DRL option.
    So I purchased a flasher module to convert it to the DRL option but when installed I still do not have the DRL. Just wondering if any of you guys have installed the flasher module on your second generation and if there is anything else that needs to be done to make things work. I have looked on the internet for a wiring diagram of the headlights with DRL and can't find anything. Thanks in advance
  2. Dec 15, 2017 at 9:11 AM
  3. Dec 15, 2017 at 5:57 PM
    Evening bump.
  4. Dec 15, 2017 at 6:11 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    That's strange you don't have that option on a limited. I have it on my 08 SR-5. I don't look at my ambers as DRL. I installed leds in my lower panel. I have them, halos, and my ambers for my DRL'S. There's a thread about the ambers as DRL's somewhere on here Prostar.
    Prostar 190[OP] likes this.
  5. Dec 15, 2017 at 6:15 PM
    Thanks for the reply it was a $30 option and about the only one I don't have. I was amazed it didn't have them either. I put in the DRL flasher module but don't know if there is something else I need to do it's been driving me nuts trying to figure it out.
  6. Dec 15, 2017 at 6:32 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah I'm not a lighting guru by any means, but we have some guy's on here that are. Hopefully they'll chime in and steer ya the right way.
  7. Dec 15, 2017 at 6:34 PM
    Thanks
  8. Dec 15, 2017 at 6:34 PM
    rons23
    Ron
    Kill Devil Hills
    Anytime
  9. Dec 15, 2017 at 6:40 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Weird. What you have for drl’s than? Nothing?
  10. Dec 15, 2017 at 6:59 PM
    Nothing if you didn't pay the $30 option then you just don't have them. From what I have found it's just a different flasher module.
    One would think when you have GPS, sunroof, leather, dual climate control they would have just gave you that option.:annoyed:
    Y0TA PR0[QUOTED] likes this.
  11. Dec 15, 2017 at 7:09 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That f**ked up. I thought I’d was mandatory by law to have vehicles with drl’s since 1990.
    In Canada It was anyway. Dunno about the US
  12. Dec 15, 2017 at 7:51 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Well sorry I was no help. Hopefully you find a way to make them work bud.
  13. Dec 15, 2017 at 7:53 PM
    Thanks
  14. Dec 16, 2017 at 9:20 AM
    Saturday bump.
  15. Dec 16, 2017 at 11:32 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I was offered DRL's on my 2010 and declined:rolleyes: I'm glad my Sales rep talked me into Bluetooth though:thumbsup:. Now that I've seen 'em everywhere, I wouldn't mind having DRL's. I've had the Fog-Light Mod now for several years and the DRL's would be a benefit to me too. Just like Prostar 190, I thought the $50 flasher was all that was needed to activate them:notsure:.
  16. Dec 16, 2017 at 11:46 AM
    Unfortunately I believe that more is involved to have them. I may have a lead on the fix.
  17. Dec 21, 2017 at 6:26 PM
    Well update got the DRL working now it requires two relays for it all to work. I took 2 hours tonight to solder it ,heat shrink and liquid electrical tape all the connections.
    Now everything works like it should.
    Y0TA PR0 likes this.
  18. Dec 21, 2017 at 6:36 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Glad you got it working bud.
  19. Dec 22, 2017 at 1:29 AM
    CMB
    CMB New Member
    Cecil County MD.
    If you should get time, tell us how, where and which relays you used.
  20. Dec 22, 2017 at 2:43 AM
    I can give you the instructions later but it takes 2 universal single pole double throw 30/40 amp Bosch style relays.
  21. Dec 22, 2017 at 6:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What the heck? In our 07 Sienna it was pull or plug in a jumper fuse in the fuse box under the hood. Toyota...:rolleyes:
  22. Dec 22, 2017 at 6:58 AM
    I guess if you had DRL factory then the ECU has the relays in it and if not then you have to install them external.
    Wynnded[QUOTED] likes this.
  23. Dec 22, 2017 at 6:04 PM
    Here's some info on the procedure.
    DA021DD2-6D7F-4DE4-B613-ED287A40AB8A.jpg 8EAC29FF-A66C-4B02-8BDD-BB6A0CFEEA06.jpg DC1BFC73-C9AE-4E54-B043-A7DC43CEBFD4.jpg 1E6592DC-76CF-44D8-B8C3-124913E3A8B8.jpg 0531E122-1BAC-47AD-8DB8-4C0131807168.jpg E3E726FA-2B1C-47B9-AC6D-8894F18152ED.jpg CFEEB44F-0E52-4565-8919-F5550C47E8A1.jpg C6FB9F35-9B7C-4D43-AD0E-8C00F793DCE9.jpg 56E311C6-370A-4CC2-9B46-33485533BA25.jpg 89CE4146-3F27-4AED-8BEC-2A278B5F77C3.jpg
  24. Dec 22, 2017 at 6:21 PM
    Here's a picture of where I brought the wire heading to the headlights through the firewall.
    This is the area where the factory wiring comes through and they have an empty rubber nipple just below the wires.
    This is a close up of the rubber nipple I made a small slit in the end. Then ran the wire through the slit and once I was done smeared a small dab of RTV silicone on the end to seal the slit.
