Driving down hwy and it dies
Discussion in '1st Gen Tundras (2000-2006)' started by Valler, Dec 31, 2018.
  1. Dec 31, 2018 at 6:58 AM
    Valler
    Valler [OP] New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    I was driving down the hwy around 55 to 60 yesterday after doing some shopping stopped at 2 stores truck turned on good and everything, well while I'm driving the truck turns off looses all power still had instrument lights on and everything just engine has no power will turn over and try to crank but wont start. So had it towed to my sisters house since it was closer to tow and cheaper also,
    Any idea I should start looking into before I have a mechanic check on it,
    Truck would struggle to turn on in cold weather like below 30 degrees Fahrenheit but would start good in temperature above 30, also at night the interior dash and dome lights would brighten up if I was in park a d would accelerate a little or would flicker to the rhythm of the blinker light,
    Last night went to go get some tools for work and tried to crank it and it's like low on juice barely wants to crank or turn over but it would try to crank much harder before when It first died on me,
    My guess is the alternator still had enough power to try harder before and it was like 6 hrs later I went to try to crank it and it was weaker,
    Any ideas of what it could be anything would help guys thanks
  2. Dec 31, 2018 at 7:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you already rule out the alternator as the cause?
    OR18TRD and Valler[OP] like this.
  3. Dec 31, 2018 at 7:12 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Try a battery
    OR18TRD, 15whtrd and Valler[OP] like this.
  4. Dec 31, 2018 at 7:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Battery, alternator, fuel pump. In that order.
  5. Dec 31, 2018 at 7:17 AM
    Valler
    Ramon
    Going to get the tested and check today after i get off work to be sure it's either one of those wishing on that it's either one, and nothing major
    OR18TRD and Watt maker like this.
  6. Dec 31, 2018 at 7:19 AM
    Valler
    Ramon
    How would I check the fuel pump? I had pumped gas like 15 min before it happened, I went to kroger and put gas then went to petsmart and left petsmart fine turned in good and went to leave and on hwy it just quit
  7. Dec 31, 2018 at 7:23 AM
    RonW
    RonW New Member
    If the alternator was bad the battery would be completely dead when it shut off on you wouldn't it?
    Its turning over weaker now because of all the start attempts and that's draining the battery.
    When you try to crank it is it trying to fire or is it just spinning? Like its starved for fuel?
    Filthyphil and 15whtrd like this.
  8. Dec 31, 2018 at 7:26 AM
    15whtrd
    15whtrd Mr. Blonde
    No codes coming up?
    OR18TRD and NewImprovedRon like this.
  9. Dec 31, 2018 at 7:29 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Quick way to see it's running is you have someone turn the key to the on/not start position and stick your head by the fuel tank and see if you can hear it running.
    More involved is to get a pressure tester and check for correct pressure at the fuel rail.
    15whtrd likes this.
  10. Dec 31, 2018 at 7:29 AM
    15whtrd
    15whtrd Mr. Blonde
    I find it a little curious that you had just filled up with fuel before it happened. Possible bad fuel? I wonder if the fuel evap charcoal canister is somehow causing this. Do you top off when you fill up?
  11. Dec 31, 2018 at 7:40 AM
    Valler
    Ramon
    I usually top it off til it fills up, when I bought the truck the low fuel light was always on and like 3 times since I owned the tru k and the tank will be full the fuel gauge will slowly lower itself to low or halfway and then regulate its self back to full
  12. Dec 31, 2018 at 7:42 AM
    Valler
    Ramon
    Only codes before that was the one for either the o2 sensor or the cats and my mechanic. Erased them and came back and said it could either be full cats or the o2 sensor or reading bad because of the headers on the truck
    15whtrd[QUOTED] likes this.
  13. Dec 31, 2018 at 7:42 AM
    15whtrd
    15whtrd Mr. Blonde
    I have just heard it’s bad to completely top off the fuel neck. Once the pump shuts off, that’s as much gas that is going in my truck. It’s bad practice to keep squeezing in every drop. It can damage the charcoal canister.
    It almost sounds like they were one of those people that would only throw 20 bucks in instead of filling up. Over time it seems that can cause the fuel Gage to act up. At least that’s my experience.
    OR18TRD and rebmo like this.
  14. Dec 31, 2018 at 7:44 AM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    I had a Grand Prix years ago that would do this, I would have to shift into neutral going 70, start it back up, then shift into gear, it ended up being an O2 sensor. May not have anything to do with your issue but may be worth checking. No codes?
    Edit: just saw your update, replace O2 and see if that fixes issue, it did for me back then
  15. Jan 1, 2019 at 8:13 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Ever figure it out?
  16. Jan 2, 2019 at 4:51 PM
    Valler
    Ramon
    Its at the shop right now, mechanic called and said looks like the timing belt slipped or something caused it to move and slip but hes still working on it said could be a crankshaft sensor, i will update once i know more or gets fixed
  17. Jan 3, 2019 at 8:12 AM
    Valler
    Ramon
    Whats a reasonable price to pay for a complete timing belt kit to be changed? I just want to see for when my mechanic gives me a price
    Filthyphil likes this.
  18. Jan 3, 2019 at 8:34 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Depends on labor rates in your area.
    My mechanic charged $400 in labor for me providing parts (about $300) and coolant. Dealer quoted me $1100.
    OR18TRD and 15whtrd like this.
  19. Jan 3, 2019 at 8:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The stealership charged me around $950 to do the timing belt and water pump. If you shop around I think you could find a better deal. Some here reported getting the water pump, timing belt, thermostat and one other part(can't remember) done as a package for around $900. Made me feel like an idiot for paying more for less.
  20. Jan 3, 2019 at 10:25 AM
    Professional Hand Model
    Hand Protectors
    Prices around here range from $900-1200 for timing belt and water pump change out. Thats materials and labor. Think I paid around $1100 a few years back.
    Next go around at 180k miles I’ll be doing the above plus those bearings, tensioner, and new radiator. Basically, everything in that slot between the grill and engine block. Might even do the alternator as it seems they go bad in the 200k range.
    Do it all at one time in my case.
    turf and Filthyphil like this.
  21. Jan 3, 2019 at 5:09 PM
    Filthyphil
    Phil
    No more than $700-800 with Aisin parts
    Black Wolf likes this.
  22. Jan 3, 2019 at 5:20 PM
    Valler
    Ramon
    Mechanic told me it will be $500 for the whole kit and labor, apperently my truck was eating the belt somehow so it only had like halfway of the belt going and it stretched so it caused for the truck to cut off on me
    Black Wolf and Filthyphil like this.
  23. Jan 3, 2019 at 5:22 PM
    Hand Protectors
    Man. I’d love it if those low prices were near my hometown. Hope you get your truck back soon.
    Valler[QUOTED][OP] likes this.
  24. Jan 3, 2019 at 5:31 PM
    Valler
    Ramon
  25. Jan 3, 2019 at 5:59 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Seeing as how it's an interference engine I'm really surprised nothing was damaged due to that belt issue. Sounds like it just off as a safety precaution possibly. That's good news at least. Had the timing belt never been changed? They are required every 90k but many have gone well into the 100's on the original belt.
  26. Jan 3, 2019 at 6:27 PM
    Filthyphil
    Phil
    They are interference engines, when my girlfriends snapped leaving the grocery store the Toyota mechanic said he’s never seen a belt break and actually cause the valves to slap. But he said he has heard of it happening if your accelerating hard when it breaks
    FirstGenVol[QUOTED] likes this.
  27. Jan 3, 2019 at 6:28 PM
    Valler
    Ramon
    Guess i was lucky nothing else was damage knock on wood, i mean the truck has 171k but mechanic said it looks like someone else did work to the engine and stuff seemed out of place, and the the gears/pulleys for the timing belt were all bent and crap
  28. Jan 3, 2019 at 6:33 PM
    Valler
    Ramon
    Tomorrow when i go pick it up ill see if he has the old belt he took off and ill try to post pictures
  29. Jan 4, 2019 at 4:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thanks. My phone turned interference into interface.
    So apparently having a timing belt snap on these engines may not always be catastrophic. That's good to know. I'm still not brave enough to go past 90k.
  30. Jan 5, 2019 at 5:33 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    So the odd thing is...if your belt was getting chewed up you would of heard some kind of noise prior to all of this, and further more, what is the definitive cause? If he doesn't know, then how do you know it wont happen again? Like did the last idiot put the guide shield on the lower pulley on backwards, was the tension pulley the fault, a bearing??? Of course I'm sure all is well and he gave you a guarantee.
