Driveshaft replacement.
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Apr 24, 2021.
  1. Apr 24, 2021 at 8:07 PM
    Alltimehigh
    Alltimehigh [OP] New Member
  2. Apr 25, 2021 at 1:31 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    The leak may just be the transmission output shaft seal, have you looked into that?
  3. Apr 25, 2021 at 8:59 AM
    Alltimehigh
    Yes I changed the seal as I assumed that was the problem at first as well. I later noticed it was leaking out of the plug in the slip yoke that goes into the transmission.
    After multiple attempts to JB weld it, its still leaking. Replacing the yoke and the Ujoints is basically the same price as this driveshaft.
  4. Apr 25, 2021 at 12:07 PM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    I needed a drive shaft replaced on a Tacoma one time and used Tom Woods custom driveshafts. Great product and speedy production as they are made to order. They are a stout one piece driveshaft meant to reduce failures.
